Author Topic: Passenger door unlock problem  (Read 1546 times)
Offline Tezmax
« on: 05 January 2014, 14:41 »
Key fob locks all four doors and boot, but when
unlocking with fob the passenger door stays locked.
Door card off time but any idea what i should be looking for before i start
coz its pretty cold out there :wink:
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Heppy
Re: Passenger door unlock problem
« Reply #1 on: 05 January 2014, 15:03 »
Pretty common problem with an easy fix, once you take the door apart....
Here's a decent guide for you http://forums.vwvortex.com/showthread.php?1542461
Hope this helps.
Offline Tezmax
« Reply #2 on: 05 January 2014, 16:13 »
Wow, spot on reply to solve my problem, and not bad for your first post. Who's Rhyso... :tongue:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 05 January 2014, 23:12 »
Good guide off vortex :afro: i would get a replacement module and fit that i would scan with vag com first to make certain its a dodgy module (100% will be)
2000 Mkiv GTi 1.8T AGU
Offline viperjsy
« Reply #4 on: 06 January 2014, 13:09 »
hi I have the same problem sort of when I press the unlock on key fob the drivers door unlocks then I have to press the key fob again to open the passenger side is this right  thank you
Offline brett
« Reply #5 on: 06 January 2014, 13:20 »
Yes mate that's how they are ,you can get it changed to one press unlock on both doors with vag com as it was a pain in the arse with my kids
