Author Topic: whats the difference between the 150+180?  (Read 2664 times)
Offline Hiddenbhp
« on: 04 January 2014, 21:47 »
Sooo what's the difference between the 150bhp and the 180bhp gti? And before anyone says yes there is 30bhp difference! But what makes that difference? Is it purely the turbo or is there other things that gives that little more ooommmfff?
The reason I ask is unfortunalty my UAM 150bhp the engine needs replacing and I'm gunna get a recond one to go in but while I'm there and spending the money I really wouldn't mind swapping it for a 180. How can I do this? Does everything have to stay UAM as all I'm doing is swapping the block ?
Offline Lewy
Re: whats the difference between the 150+180?
« Reply #1 on: 04 January 2014, 21:51 »
The turbo is a K03s as opposed to the K03 and 1 extra gear in the gearbox.
Offline mar_k
« Reply #2 on: 04 January 2014, 21:53 »
Not sure about that one Lewy as AUM's have a K03s,
Only difference is the Map file and extra gear.
just replace the engine if yours is ruined and go for a remap.
« Last Edit: 04 January 2014, 21:56 by mar_k »
Offline Hiddenbhp
« Reply #3 on: 04 January 2014, 21:57 »
So if I were to just change the turbo to the ko3s will it work? And if I'm just changing the block can I put am AGU lump in instead of the UAM?
Offline dom
  • Back in a Mk4
« Reply #4 on: 04 January 2014, 22:16 »
It's AUM, not UAM.
Both AUM and AUQ have ko3s turbos, as has already been said the extra 30bhp is down to the mapping.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 04 January 2014, 22:54 »
I think AUQ and AUM blocks are the same
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 04 January 2014, 23:40 »
pretty certain they are
It's AUM, not UAM.
As dom and others have said,the aum and auq share basically the same engine and turbo the auq has a different map to the 150 aum engine
2000 Mkiv GTi 1.8T AGU
Offline Lewy
« Reply #7 on: 04 January 2014, 23:42 »
Oh yeah...... :embarrassed:
Offline Rhyso
« Reply #8 on: 05 January 2014, 09:44 »
Its just the ECU map thats different
Both AUM & AUQ make the same power once mapped
Offline Hiddenbhp
« Reply #9 on: 05 January 2014, 21:22 »
Can i put an AGU block into my AUM? or would i have to change things?
