Author Topic: Engine codes ?  (Read 1389 times)
Dubmanpete
Engine codes ?
« on: 04 January 2014, 19:19 »
Right I have recently bought mk4 gti 1.8 turbo , now in the book it says the engine code is ARZ  but on the block it says AUM, so either had new head or complete engine, but is there any difference as I was to buy some bits for it but don't know what engine code to match to, can anybody help me on this , will be much appreciated ??
Offline hobbiniho
Re: Engine codes ?
« Reply #1 on: 04 January 2014, 19:33 »
they are exactly the same
Offline Screech16v
  • MK3 20vt AGU
Re: Engine codes ?
« Reply #2 on: 04 January 2014, 19:48 »
aum has vvt and ko3s, arz has neither  :grin:
Offline hobbiniho
Re: Engine codes ?
« Reply #3 on: 04 January 2014, 20:12 »
doesnt mean that it has a ko3s fitted and will the older wiring loom have a plug for the vvt?? what i meant was the block is the same
Offline dom
  • Back in a Mk4
Re: Engine codes ?
« Reply #4 on: 04 January 2014, 21:28 »
Offline mcgee9t2
Re: Engine codes ?
« Reply #5 on: 06 January 2014, 12:45 »
have a look at the sticker i believe its in the boot or the door, cant remember which, see what code it says on there, then have a look at engine number and see if it matches the vin number (i believe the whole vin isnt put on the engine just part of it?) that will tell you if you have the original engine or not.
