Author Topic: waterpump  (Read 3556 times)
Offline danmusic24
waterpump
« on: 04 January 2014, 08:39 »
Is changing the waterpump a straightforward job on 16v? :smiley:
Offline xionsolaris
Re: waterpump
« Reply #1 on: 04 January 2014, 09:31 »
Its not that bad airbox out both fan belts off alternator off then take tensionsor arm bracket off then take the hoses that go to the  waterpump off  then un bolt the water pump.then take the waterpump pulley off to do thst wedge a screwdriver through that hole on the pulley change the thermostat in the waterpump clean  the engine block were the pump sits and use gasket sealer put pulley on new water pump a fit in reverse do not buy a cheap water pump otherwise you will be doing the job again
Offline bigberty101
Re: waterpump
« Reply #2 on: 04 January 2014, 10:07 »
avoid the metal impeller one from euro's now on my 3rd one! first one bearing failed, second one seal failed, 3rd on seal is now failing!
Offline Shizzle
Re: waterpump
« Reply #3 on: 04 January 2014, 10:14 »
when a water pump is failing is there any noises i should listen for i have one from euros  :embarrassed:
Also when taking water pump pulley off be careful not to round any bolts off easily done.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline xionsolaris
Re: waterpump
« Reply #4 on: 04 January 2014, 11:48 »
Ive just bought the oem quality one from euros i hope it dont fail
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: waterpump
« Reply #5 on: 04 January 2014, 12:35 »
The second one i changed sounded so bloody awful everyone thought my exhaust manifold had cracked open.
Offline bigberty101
Re: waterpump
« Reply #6 on: 04 January 2014, 13:52 »
oem one is plastic impeller, I had a new ish one break and never recovered all this bits but that was my first 14 golf. that's why I went to a metal one. and as far as the failing water pump noise to look out for, when the bearing went it was a long drone kind of sound, and then a squeal went it got so bad the belt slipped. that happened on the dually before I had chance to pull off. when the seal went I just lost coolant, no noise.
Offline Len
Re: waterpump
« Reply #7 on: 04 January 2014, 16:06 »
Dan mate its not an easy job!!
www.sas.org.uk
www.the-ace.org.uk
Offline danmusic24
Re: waterpump
« Reply #8 on: 04 January 2014, 21:31 »
Did put a post up a while ago about my car sounding like a London taxi.
someone did say waterpump,and I'm certain after investigating that it is the pump.
So the question is whats the pump to buy?
Bradley sells them think I will trust him?
Offline bigberty101
Re: waterpump
« Reply #9 on: 05 January 2014, 00:54 »
Bradley is a good guy and sells good gear, so I would say yes
