Author Topic: Premium Petrol or not?  (Read 14147 times)
Offline mk7gti
Re: Premium Petrol or not?
« Reply #10 on: 04 January 2014, 16:44 »
I've been driving 2.0 TSI cars for eight years and after two years of trying 98 and 95 RON I decided I couldn't tell any difference.  My GTI is happily running on standard unleaded.
When driving on 98 RON I always felt the placebo affect was kicking in :smiley:
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
Offline monkeyhanger
« Reply #11 on: 04 January 2014, 16:59 »
If the car is set up optimally for RON98 then it'll run better on it than 95. Some previous VWs stated that they ran optimally on 98 and could run on 95 with slight reduction in performance, but current literature doesn't state that. Seems then that the GTI is set up for 95 and using 98 is just a waste.
Offline GTI7me
« Reply #12 on: 04 January 2014, 17:09 »
I agree with you MonekyHanger.
I usually use standard shell unleaded. However i had a voucher for their Nitro+ so i used it for a couple of tanks (around 800 miles) to see if i could notice any difference in power or economy. I noticed no difference at all. I'm back on standard unleaded now. I realise that a dyno may pick up slight differences in power. I however could not.
J
2013 GTI (GONE) - 2014 GTI Performance Pack - Manual, Discover Nav, 5 door, Park Assist
Offline JoeGTI
« Reply #13 on: 04 January 2014, 18:22 »
I'm confident it makes no difference and you are wasting your money with the "premium" stuff. I'm a cynical fecker at the best of times and it wouldn't shock me if the premium came from the same tank as the regular!
I think we're all guilty of persuading ourselves a product is "better quality" especially if you've just paid a premium for it.
Offline arcamalpha
« Reply #14 on: 04 January 2014, 18:31 »
There are two separate questions. One is whether the fuel itself is any different (and therefore beneficial). The other is whether the mk7 gti (or gtd for premium diesel) can take advantage of it.
Offline Hawaii-Five-O
  • Are we nearly there yet?
« Reply #15 on: 04 January 2014, 22:55 »
Not this old chestnut again :whistle:
Run it on 95 RON.
Anything else is waste of money.
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
Offline 2014GTi
  • Das Auto
« Reply #16 on: 04 January 2014, 23:02 »
I guess everybody is entitled to their opinions, magazines and independent tests have proven the benefits countless times in the past.
Better octane fuels combust better, simple fact  :rolleyes:
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
« Reply #17 on: 05 January 2014, 09:39 »
Only if the car is optimised for it, which the current GTI is not. 98RON fuel on a car optimised for 95RON will not help it run any better. The 98 will be combusted earlier in the compression/ignition/combustion cycle than would be optimum -most likely leading to same mpg at best. Higher octane fuel Ian't necessarily more calorific, it cab be compressed further before igniting, preventing pinking under the higher compression ratio that you would expect 95RON fuel to pink at.
The GTI has a compression ratio that lends itself to running best on 95RON, older engines set up with a preference for 98 have a higher compression ratio.
Offline Poached
« Reply #18 on: 05 January 2014, 14:37 »
I thought the ECU could adjust ignition advance according to the fuel.
The benefits when tuning are well documented.
Offline Jimmgc51
« Reply #19 on: 05 January 2014, 15:43 »
+ 1
I thought that too on the fuel cap it states 95 or higher it can run on 95 but the timing will be retarded by the ECU to allow the engine to run optimally on the fuel it has avail, so putting in a better fuel will allow the ECU to run on the best mapping it has available.
I use Shell Nitro pretty much all the time now since the new engines gone in and can I tell a difference in performance??
Not really but it's only an extra £4-5 per tank and I DO get more miles out of it on the motorway. I have actually tested this umpteen times and can range an extra 30-40 miles per tank.
HOWEVER - this is driving driving like a granny at 70-75 as soon as you plant your foot down any gains unfortunately have gone out the tail pipes!
This is from my personal experiment anyway but as said for the little price it is I'm happy to pay it knowing that the engines running at its best performance..
Golf GTI 09, CW, Bi-Xenon, DCC, 18" Monza's, Jakarta, RNS510, Dynaudio, F&R parking sensors, Winter pack...
Ibiza Deep House mix for DL - https://soundcloud.com/jimmgc51/getting-deep-with-house
