Author Topic: cars dont like drinking water!!!!  (Read 3893 times)
Offline Bellend
Re: cars dont like drinking water!!!!
« Reply #10 on: 02 January 2014, 16:50 »
Instead of looking in the wrong place, get a garage to use a scethascope or however it's spelt on it
Saves mucking around. I did exactly the same on a MK4 SDI.
Where all my moneys went.
« Reply #11 on: 03 January 2014, 00:12 »
I would suspect you have bent a rod tbh.
Offline Chris.
« Reply #12 on: 03 January 2014, 01:05 »
Dead.
Click For Build Thread
Offline Shizzle
« Reply #13 on: 03 January 2014, 09:15 »
http://www.prestigeengine.co.uk/cylinder-heads.html?source=aw-head-rebuild
there are lots of people out there doing rebuilt heads so you can probably get a really good price if you can ring around.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Bellend
« Reply #14 on: 03 January 2014, 12:00 »
I can't see it being the head whatsoever.
Offline Shizzle
« Reply #15 on: 03 January 2014, 13:05 »
Well if water got into the engine it would be in with the fuel in the bore getting through the valves but instead of being burnt the piston would push the water i to the valves which could slightly bend them.
that could cause the low compression on 1 cylinder or more.
Offline leigh_harty
  • Audi AGU
« Reply #16 on: 03 January 2014, 20:14 »
1st things 1st... stop driving it  :wink: especially to see if its got any oomph
Dont lose your dinosaur!
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 03 January 2014, 20:28 »
Rod bent so slightly shortened by the sounds,no chance of doing valves through hydrolocking.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 03 January 2014, 21:04 »
another verdict of a bent rod here
Offline Shizzle
« Reply #19 on: 03 January 2014, 21:29 »
+1  :whistle:
