Author Topic: 245/40R18 18" 8J ET35  (Read 2019 times)
Offline Bellend
« on: 01 January 2014, 17:12 »
Good sizes or bad?
Wheels should be fine even if tyres not? Will need adapters so will need to factor that into the equation.
Cheers. :smiley:
Where all my moneys went.
Offline dom
  • Back in a Mk4
Re: 245/40R18 18" 8J ET35
« Reply #1 on: 01 January 2014, 17:43 »
Tyre is way too wide for the wheel, 225/40/18 is the largest you want.
Et35 doesn't a huge amount of room for adaptors, you want 15mm if you can get them which will give you a final offset of Et20 all round.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 01 January 2014, 23:55 »
I have 15mm on the back and 5mm on the front of mine with 8J and 225/40 tyres. 245 will look crap
Offline Bellend
« Reply #3 on: 02 January 2014, 00:23 »
Ah well bought em. Have seen some adapters so will grab those. Off a Vito and the car won't be lowered straight away so hopefully it won't look too crap.
Kinda needed a wheel after ramming into a kerb at 60mph avoiding a serious accident which left a mate in hospital.
Surprised how well it held up, slightly knocked tracking out and bent the wheel a bit but everything else is golden!
Offline Bellend
« Reply #4 on: 02 January 2014, 17:18 »
Do we feel 20mm adaptors would be completely out the question?
I'll probably sell the tyres on they're all fairly good.
Offline dom
  • Back in a Mk4
« Reply #5 on: 02 January 2014, 17:41 »
With those tyres, yes. I'm running 20mm spacers on the rear of mine with the same wheel specs and with 225/40/18 tyres they caught like mad, I swapped to 215/40/18 and they still caught when running low.
Offline Bellend
« Reply #6 on: 02 January 2014, 17:44 »
Hmm I don't want the hassle really. Maybe 15 would be best. What are the 215 tyres like mate?
Offline dom
  • Back in a Mk4
« Reply #7 on: 02 January 2014, 18:06 »
215/40/18 are more expensive than 225/40/18, they give a tiny bit of stretch and I got on with them fine. If it were me, unless you're running very low, I'd use 15mm adaptors and 225/40/18
Offline Bellend
« Reply #8 on: 02 January 2014, 18:54 »
OK cool. Just some tyres to look for then!
Bloody expensive compared to 15s. :grin:
Offline dom
  • Back in a Mk4
« Reply #9 on: 02 January 2014, 19:13 »
They are aren't they, take a look at the prices of 205/35/18's :shocked:
I've just fitted 4 of them to mine :grin:
