Author Topic: bad brakes  (Read 9257 times)
Offline Screech16v
  • MK3 20vt AGU
Re: bad brakes
« Reply #30 on: 03 January 2014, 20:15 »
All the nipples are pointing up, yes?
This could be funny
Sharki you havnt answered this question,have you got the calipers on the correct sides? nips up?
Offline sharki786
  • GOT BOOST??
Re: bad brakes
« Reply #31 on: 03 January 2014, 21:33 »
This could be funny
Sorry screech mate, ye they are pointing up. U could put them wrong side but the hand brake cable gets funny to put on.
Well tried with the eezibleed. No luck. The pedal is soft 3/4 way down and then bites before it goes to the bottom and if i push anymore then its the end of the travel. Well i was speaking with mad4vws and he has a few. Which make should i get if i buy a new one? I could buy a refurb kit from bigg red and replace the worn seals?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: bad brakes
« Reply #32 on: 03 January 2014, 21:55 »
Just get a good working secondhand one off mad  :wink:
Offline sharki786
  • GOT BOOST??
Re: bad brakes
« Reply #33 on: 03 January 2014, 23:44 »
How can i check to see if the servo is ok and not loosing pressure??
Could the 16v & vr owners tell me where the pipe comes from for the hydro clutch? Is it the clear bottle, were you put the brake fluid in?
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: bad brakes
« Reply #34 on: 03 January 2014, 23:51 »
P.s what size is the piston is it 23mm? And which has the largest piston on the mk3?
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: bad brakes
« Reply #35 on: 04 January 2014, 00:21 »
Pipe comes off the side of the brake res for the hydro clutch,biggest master cylinder will be the later 96 onwards with 288 brakes
Offline tweed
Re: bad brakes
« Reply #36 on: 04 January 2014, 09:55 »
Its fitted to all 16v and vr6.
I had 280mm brakes on my 95 abf but had the big master cylinder.
Offline sharki786
  • GOT BOOST??
Re: bad brakes
« Reply #37 on: 14 January 2014, 07:39 »
Just thinking about replacing the master cylinder. But i am VERY close in buying a vr6 and dumping that in there thats why i asked were the pipe comes off for the clutch
*****MK4 GTI T*****
