Author Topic: Looks pretty knackered but what is it?  (Read 7469 times)
Offline Jasikasisback
Re: Looks pretty knackered but what is it?
« Reply #10 on: 01 January 2014, 02:56 »
I didn't have too much trouble doing it other than the engine dropping and scaring the hell out of me when I pulled the starter off...I even had the engine supported by a two ton jack but still managed to drop a bit..
The cost here is relative I think as if you put a cheap crank sensor on (£15-20) vs a better one for £50 then you might end up doing the job again really soon...
I know some engines you don't have to remove anything except the oil filter...(lucky them) mine was a AGG so had to remove engine mount, starter...and then got it off...
will take more than 30 minutes the first time you do it...and you can lube up the starter when you take it off if you have to remove it...:)
Everyone will need to do this job sooner or later....but you get to know your car better...:)
Makes me very reluctant to sell mine hearing all the horror stories about particulate filters and EGR valves...etc etc....
Stick with the golf...where else can you get used parts from other owners for cheap? Even new replacement parts are not really expensive...:)
Good luck in changing the crank sensor...then make sure your timing is right and most likely your car will be good to go!
Offline Shizzle
« Reply #11 on: 01 January 2014, 11:44 »
Yeh will replace everything done thermostat already that was a pain in the ar5e have to remove so many mounts and bolts.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Len
« Reply #12 on: 01 January 2014, 11:52 »
I cant understand how you say it was easy!
I can only assume you are doing it on a non aircon car with only one fan hence the fan motor is not in the way of one of the big starter?engine mount bolts!!!
www.sas.org.uk
www.the-ace.org.uk
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
« Reply #13 on: 01 January 2014, 17:10 »
I have replaced the crank position sensor on both 8v's and 16v's and yes it is more difficult with the air con fan and evaporator in the way but if you remove the front mount bolt first and jack on the bell housing to tilt the engine back a couple of centimetres it gives more room.
At the end of the day its just 3 nuts 3 bolts and a cap head bolt.
New toy1990 Scirocco I feel a 16v conversion coming on.
« Reply #14 on: 01 January 2014, 22:14 »
No no aircon on mine. Guess I was lucky..in that sense...
Offline Ninja
  • 19 smiles per gallon
« Reply #15 on: 01 January 2014, 22:14 »
That's a crank sensor - awful, awful job - was a front end off job for me because everything had rusted and rounded.
Offline Len
« Reply #16 on: 02 January 2014, 11:04 »
Everything is awful!
I have never worked on a car that was so complicated before!
I thought my Pug 405 Mi16 was bad but this is incredible!
I need to take everything off my engine to fit onto the new as that is just a block and head (with new internals of course!)
So many brackets and mountings that are inaccessible!
How you are supposed to reach some bolts/nuts I just dont know!
www.sas.org.uk
www.the-ace.org.uk
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #17 on: 02 January 2014, 11:07 »
Surely it cant be that difficult to transfer parts from one engine to another if theyre both removed and on the bench / stand?
Offline Bellend
« Reply #18 on: 02 January 2014, 12:17 »
Why don't you just disconnect the down pipe from the cat?
That's all I ever do.
Where all my moneys went.
Offline Len
« Reply #19 on: 02 January 2014, 12:31 »
Dont have that kind of room.
Dont have an engine stand either.
My bench has go the new head on it at the moment. I still have to reassemble the new engine and was thinking if I took stuff off in sequence and put them onto the new engine that would be best as bolts etc. wouldnt get lost or rather I would not need to label everything.
But hasnt worked out that way.
www.sas.org.uk
www.the-ace.org.uk
