Author Topic: Wheel PDC issue - Help required ASAP  (Read 1638 times)
Offline profx
« on: 29 December 2013, 20:49 »
Right i have a Golf MK4 V5 (170)
Now was hoping to get some new 3SDM 006's tomorrow. Today i took off my current TSW that come with the wheels and they read 5x120 8J ET35 on the back. Now i thought golf mk4's had 5x100!
So now scratching my head, so do i get 5x120's?
May seem a little strange but I'm confused as the only thing i can find listed with 5x120 is the touareg.
 :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided:
Offline mcgee9t2
Re: Wheel PDC issue - Help required ASAP
« Reply #1 on: 29 December 2013, 21:36 »
PDC isn't 5x120. Think that's BMW figment.
Sure you haven't got adaptors on?
If not my guess is someone's had the wheels welded up and re-drilled.
Offline dom
  • Back in a Mk4
« Reply #2 on: 29 December 2013, 21:52 »
Mk4 is definitely 5x100 :wink:
Offline joshstanvw
« Reply #3 on: 29 December 2013, 22:00 »
Here's what I usually go by
I would also get a tape measure out and measure to make sure 100mm to 120 is a fairly big difference so you would know which it is
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 29 December 2013, 22:48 »
you could also throw a pic up...
Offline Lewy
« Reply #5 on: 29 December 2013, 23:09 »
PCD.
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 30 December 2013, 11:39 »
Seen a lot of aftermarket wheels with pcd stamps that don't match the actual pcd of the rim ,mk4 is defo 5x100 so don't worry about it
