Golf mk2
Strange sound
Topic: Strange sound (Read 2785 times)
Mcwill
Here all the time
Strange sound
28 December 2013, 16:41 »
Hi guys, after covering a couple of hundred miles in my rebuilt abf engine conversion I have noticed there is whining noise coming from what I think is the alternator?
As far as I'm aware the used the alternator off the 8v engine. Is the noise normal or is there a reason? Any ideas
Gambit
Forum addict
Re: Strange sound
28 December 2013, 17:15 »
Belt over tightened? Itll put extra strain on bearing and cause them to whine. Simple solution is remove belt start car and see does it whine
Mcwill
Here all the time
Re: Strange sound
28 December 2013, 17:24 »
Cool cheers gambit.
Sgt_Lemon
8v owners club
Re: Strange sound
29 December 2013, 09:42 »
Leave it and tell everyone it's supercharged?
Mcwill
Here all the time
Re: Strange sound
30 December 2013, 21:15 »
Turned out to be power steering pump.
Sgt_Lemon
8v owners club
Re: Strange sound
01 January 2014, 16:54 »
You sure it's the pump itself? Mine whines occasionally but if I go full lock a few times it stops. I have a slight leak in the LP hose so air gets into the system and makes the noise, going full lock bleeds the air through.
Mcwill
Here all the time
Re: Strange sound
Reply #6 on:
01 January 2014, 17:09 »
Just what the garage have told me, they said they removed the powersteering belt and the noise stopped. Haven't had it fixed yet.
Sgt_Lemon
8v owners club
Re: Strange sound
Reply #7 on:
02 January 2014, 08:15 »
If you find a place that will actually replace the hose without spending a fortune post back. Any hydraulic place round here won't do any work if it's for pas or fuel.
Gambit
Forum addict
Re: Strange sound
Reply #8 on:
02 January 2014, 11:41 »
what colour/condition is the power steering fluid? id be inclined to change that first, along with new belt and correct tension.
Sgt_Lemon
8v owners club
Re: Strange sound
Reply #9 on:
02 January 2014, 13:49 »
When you drain it have a look not only at the colour of the fluid but to see if it has and metal in There. Indication of damage elsewhere in the system.
Golf mk2
Strange sound
