Author Topic: pd150 vag com run help please  (Read 5261 times)
Offline scottv6
« on: 27 December 2013, 18:44 »
went out today to do some runs with vagcom to find my boost problem,while out I blew the turbo  :sad:
which ended in a cloud of white smoke.  before it went I managed to get some logs, can anyone shed some light on the graph and what problems there is please.
Offline Rhyso
Re: pd150 vag com run help please
« Reply #1 on: 27 December 2013, 23:27 »
Overboosted
Actual vs specified should follow each other. It will spike above then it should come back and trace it
With 180k on the clock it was past its sell by date  :sad:
Sticky vanes is the most likely cause
When you replace the turbo make sure you clean the intercooler out; renew the boost pipes (if not already done) and make sure the actuator is set up properly
