Author Topic: Ouch engine mount dismantled itself  (Read 1115 times)
Offline joshstanvw
« on: 27 December 2013, 17:47 »
Hi all I was just pulling into my parking space at home I selected reverse then got a loud crack come from the engine bay and on closer inspection I found that the near side engine gearbox mount had cracked and broke in half and both bolts to the box side had broke I have removed the offending parts does anyone know if I can replace these with the parts from a 2.0 Gti
as a mate has one on his drive that is being scrapped?
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline Winniee
Re: Ouch engine mount dismantled itself
« Reply #1 on: 27 December 2013, 22:20 »
Similar thing happened to me and I had my old 2l breaking.
My 1.8 is an AGU and the 2l mounts are the same as that.
GolfGTIForum Build Thread -
http://www.golfgtiforum.co.uk/index.php?topic=263142.0
Something breaks? Upgrade it!
Offline joshstanvw
« Reply #2 on: 27 December 2013, 22:42 »
brilliant mine is an AGU also so ill be all good to go in the morning thanks for the reply fella
Offline joshstanvw
« Reply #3 on: 28 December 2013, 11:57 »
All done and sorted really easy job really thanks for the reply had to replace the clip on the inner cv boot as it had popped off but seems all good
Offline Winniee
« Reply #4 on: 28 December 2013, 12:03 »
My box fell onto the shaft but I don't think it broke anything. Will be upgrading it all anyway.
