Author Topic: MK5 GTi common faults  (Read 8708 times)
Offline D Squared
« on: 24 December 2013, 09:44 »
Hi Guys,
Just about to buy one, its got just over 50k on the clock full VWSH
What are the common faults?/what should i look for?
DMF? etc??
MK3-MK5- Now MK7 GTi
Offline th3_f15t
Re: MK5 GTi common faults
« Reply #1 on: 24 December 2013, 11:07 »
Apart from just checking how it feels, check the history for any major work. There was a recall on these cars for the coil packs, however if its a later GTI then you may have got away with it.
There are loads of threads here with problems people have had, browse through and read what they were and what was the cause, then just use that as a guide to help you look over the car.
Also take a friend, second set of eyes is always good.
Moving over to Flickr, sorry for the broken picture links!
Offline D Squared
« Reply #2 on: 29 December 2013, 09:25 »
Thanks for that, I bought the car, picking up in New Year :)
Offline th3_f15t
« Reply #3 on: 29 December 2013, 09:45 »
Nice one. I would personally send it into a dealer for a full health check and diagnostics, think they're free with any work done or a few quid, but it'll give you a detailed list of anything you should repair or at least be aware of. Any parts they say needed will be listed with part numbers which you can then use online to look for a better deal.
Offline D Squared
« Reply #4 on: 01 January 2014, 17:59 »
Hmm, thanks for that, may just do that..
The car has full VW service history, and covered 52k...
Want to get mud flaps all round for it, and some privacy glass of rear half...looking forward to becoming a mk5 owner....
Offline Ninja
  • 19 smiles per gallon
« Reply #5 on: 01 January 2014, 22:12 »
Check
RUST ON FRONT ARCHES
CAM FOLLOWER WILL NEEED REPLACING (guides on youtube).
THERMOSTAT FAILURES
CHECK ALL ELECTRICS
MECHATRONIC UNIT IF DSG
And many more that you'd normally check with a used car.
Offline D Squared
« Reply #6 on: 02 January 2014, 13:54 »
cheers for that, i'm hoping at 52k i shouldn't need much of that....
Offline barrym381
« Reply #7 on: 02 January 2014, 14:01 »
mileage will not stop rust an check see if its had the coil packs done yet  :wink:
http://www.volkswagen.co.uk/owners/recallsSubmit
Offline Ninja
« Reply #8 on: 02 January 2014, 15:22 »
Mine at 67k needed all of that. FSH.
Cam followers are a know weak point and last around 20-30k causing cam damage if not replaced. Check the follower was replaced.
« Last Edit: 02 January 2014, 15:25 by VdubNinja »
Offline Ninja
« Reply #9 on: 02 January 2014, 15:24 »
Plus wheel arch rust is an inherent design flaw. The wheel arch liner rubs the arch to bare metal causing corrosion and VW claim it's a mechanical fault - only currently offering 50% towards the repair leaving around £500 to pay - so check and haggle.
