Author Topic: driveshaft question  (Read 2154 times)
Offline vwwvgolf
driveshaft question
« on: 23 December 2013, 19:46 »
evening!
 ive been talking to a guy from a gearbox refurb place. i plan on getting the box out in the near future to fit the flywheel, and while its out ive decided to go for changing the final drive and get it refurbished at the same time. his asked if the driveshafts are a 'pop' joint fit or ones with a 6mm allen in the middle??
not to savvy with all this lol
Offline spikenipple
Re: driveshaft question
« Reply #1 on: 23 December 2013, 20:32 »
I'm pretty sure they just sit slightly inside the output flange and bolt on around the periphery of the driveshaft...
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 23 December 2013, 21:44 »
The cups  just bolt  in from the middle ,well 16v and vr do
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #3 on: 24 December 2013, 07:29 »
If you have the TC or the VIN number I can check for you
Offline vwwvgolf
« Reply #4 on: 24 December 2013, 11:27 »
yeah as far as i was aware they sat inside then bolted up around the outside.
unfortunately i haven't got any numbers with at the moment.
ill tell him they bolt up as far as i know.
thanks guys :smiley:
