Author Topic: Fault codes help  (Read 2709 times)
Offline Eddy
Fault codes help
« on: 22 December 2013, 12:03 »
Hi Folks, Recently joined and i have been searching around a bit for these fault codes but i could do with a bit of help please identifying the exact problem?
Purchased the car a couple of months ago and i have been told the 02 sensor is playing up because it has a 3" downpipe with decat so the sensors are getting to much flow? (new sensor fitted 2/4/13 )
I have also changed the temp sensor because of code P1296 but code keeps coming back?
1, P0130 Generic 02 sensor circuit malfuntion ( bank 1 sensor 1 )
2, P0135 02 Sensor heater  circuit malfuntion ( bank 1 sensor 1)
3, P0036 H02S bank 1 sensor 2 heater circuit
4, P1296 Cooling system mafuntion
Car is golf 1.8t with a stage 1.5 custom remap by r-tech and it is giving crap mpg
Any help would be much appreciated  :smiley:
Golf 1.8t , Custom R-tech 1.5 remap 202bhp , 3" downpipe with decat , Pipercross panel filter , Forge 007 , Silicone TIP, Oil catch can , 18" S8 alloys , De-badged & de-wipered
Offline Eddy
Re: Fault codes help
« Reply #1 on: 24 December 2013, 15:26 »
Nobody ?
Offline mike1990
« Reply #2 on: 24 December 2013, 17:28 »
1 - Check the wiring, or replace o2 sensor
2 - Check wiring, or replace o2 sensor
3 - Check wiring or replace o2 sensor
4 - Coolant temperature sensor or coolant thermostat
Offline Eddy
« Reply #3 on: 24 December 2013, 18:59 »
It had new 02 sensors about 6 months as well as thermostat and I have just replaced the temp sensor. I also forgot to add that sometimes the car kangaroos a bit when pulling away? Just wondering whether it could be anything do with the maf sensor?
Offline mike1990
« Reply #4 on: 24 December 2013, 19:57 »
Yes, I'd be checking the spark plugs, coil packs and the MAF sensor for that. Try and clear the codes, go for a drive and rescan and see what comes back
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 29 December 2013, 10:11 »
Try unplugging the maf  for the kangarooing,car wont boost when unplugged but it should be smooth,or clean the maf and throttlebody first
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 29 December 2013, 11:30 »
Were the codes cleared after the parts were replaced?
Offline Eddy
« Reply #7 on: 31 December 2013, 17:12 »
The mil light was on when i purchased the car so i did a scan and it only showed up the 02 sensor which the guy said is on because it has a 3" downpipe with decat so there is to much flow going past the sensor?
I unplugged the maf sensor plug earlier and it seemed to run a bit better when i took it around the block? (Got a 2nd hand 1 on order which is fully working)
I also cleaned the throttle body today and to be honest it was pretty clean to start with.
Going to order a thermostat and change that as i have already changed the temp sender?
