Author Topic: Gloves on the touch screen...  (Read 6100 times)
Offline ajmoir36
« on: 22 December 2013, 09:38 »
Does using gloves on the touch screen work? I wear gloves on those really cold days and can still use the RCD510 in the mk6 whilst wearing them. Does it also work wearing gloves with the mk7 screens?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline watson
Re: Gloves on the touch screen...
« Reply #1 on: 22 December 2013, 10:29 »
Yes it works fine.
Offline monsta
« Reply #2 on: 22 December 2013, 10:33 »
Probably depends on the glove material but you can always upgrade to some North Face Etip Gloves
http://www.simplyhike.co.uk/products/TheNorthFace/MensEtipGlove-AsphaltGrey.aspx
Offline FNJ-GTI
« Reply #3 on: 22 December 2013, 11:12 »
Wearing gloves means the touch screen doesn't work for me. Leather gloves seem to not respond. Bit annoying.
Offline rocknob
« Reply #4 on: 22 December 2013, 16:46 »
It's because it has a capacitive touch screen. Same as most smart phones. The RCD510 had an older generation touch screen. Basically the newer touch screens use the conductivity of your finger to "close" the circuit on the screen. I have seen touchscreen gloves at a couple of gadget type shops.
Current Car :  Tornado Red VW Golf GTI DSG DCC ParkAssist Xenons
Offline watson
« Reply #5 on: 22 December 2013, 18:03 »
Really odd my gloves are leather and it works fine on my DNS screen.
Offline monsta
« Reply #6 on: 22 December 2013, 22:47 »
A lot of leather glove wearers on here  :whistle:
Offline Sootchucker
« Reply #7 on: 23 December 2013, 07:44 »
Unless the gloves have an etip, then i wouldn't expect them to work with the units in the MK7.
The touch screen units are quite different to those used in the older RNS-510. The RNS units used a resistive type of touchscreen, whereas the units in the MK7 use capacitive type.
The resistive touchscreen itself is made up of several layers, the topmost of which flexes under your finger or stylus, and is pushed back onto a layer behind it. This effectively completes a circuit, telling the unit which part of the screen is being pressed. This then is irrespective of whether the user is weather gloves or not, it just relies on pressure.
The capacitive units in the MK7 touchscreens don’t rely on pressure, but rather they use electrodes to sense the conductive properties of objects, such as your finger. So, they don’t rely on having an object pressing particularly hard on their surface, but will only react to certain objects. Prod one with a standard stylus or gloved finger and you’ll get nowhere. Using a capacitive type (like mobile phones), allows the gestures such as pinching the screen to zoom in on the nav screen or dragging the time line on a music track form instance.
« Last Edit: 23 December 2013, 07:47 by Sootchucker »
Offline ajmoir36
« Reply #8 on: 23 December 2013, 09:31 »
That's a bummer for the winter months.
Offline rallypug
« Reply #9 on: 24 December 2013, 20:49 »
.... Try putting the heater on ....B-)
5 Door, Manual,  Perf Pack, Tornado Red, Winter Pack, Adaptive Chassis, Sat Nav ....
