Well you guys said: "Other than that, you could have a faulty maf, lambda sensor, N75 or a weak actuator."
I have ruled out the MAF sensor, disconnected it and wow it ran like a bag of crap lol, no power at all and idling problems all over.
Unsure on lambda or N75 without buying new ones sadly, not sure about weak actuator...
However, at Vee Dubs, he did check it out and say it was wet on the small pipe that sits under the turbo cover/injectors (where the dip stick is) he said that was wet and could cause problems?
Although he did say these turbos do drop off at higher range as they arent the KO3S? that keep going all the way?
Think I will be asking for a refund... about to get awkward.
Edit - Vee Dubz (Where the tuner gold me to go) said themselves that the forge 008p DV wont be a problem and if anything would be better. So lets hope I can sort something
