Author Topic: Engine running funny on warm up  (Read 1595 times)
Offline rfn_hodgson
« on: 21 December 2013, 13:46 »
Hello lads when I start the engine up in the morning I do leave it till the choke goes off.... Then I drive off and the car splutters under power for the first mile then it's fine after that
When I say power I literally mean just coasting it through the gears
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Nino
Re: Engine running funny on warm up
« Reply #1 on: 21 December 2013, 13:55 »
That could be a number of things bud, however it seems that this could be Air/Fuel related.
Unfortunatly that could so many things I.E..
* Coil packs.
* Spark plugs.
* Lambar sensor before CAT.
* Lambar sensor after CAT.
* Temp sensor.
* Boost leak.
* Faulty DV.
* Faulty CAT.
* Faulty injectors.
* Faulty MAF.
* Leaking injector seals. (Would also come under boost leak)
* Leaking injector seats. (Would also come under boost leak)
* Rocker cover gasket leak. (Would also come under boost leak)
* Inlet manifold gasket leak. (Would also come under boost leak)
* Throttle body gasket leak. (Would also come under boost leak)
* Faulty throttle body.
* Dirty throttle body.
* Faulty sensor located directly bolted into the inlet manifold just next to the TB.
* Faulty MAP sensor located in the intercooler.
* Faulty AMP thingy thats bolted into your airbox (Not sure is this only applys to AGU engines).
* Big carbon buildup, use "Slick 50" to help clean it up. Only use it once every 4000 miles.
* Or if you have been using an induction kit ensure you haven't been using an "oil coated" cone, these kill MAF's.
You can clean a MAF using eletronic contact spray.
However the best thing you can do is scan your car with vagcom first.  :nerd:
« Last Edit: 21 December 2013, 13:57 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline rfn_hodgson
« Reply #2 on: 21 December 2013, 16:45 »
Had it scanned and no codes that's why I'm stumped
Offline navmk4gti
« Reply #3 on: 21 December 2013, 19:20 »
Or may be due to the problem you have in the below thread you made
Offline dom
  • Back in a Mk4
« Reply #4 on: 22 December 2013, 10:35 »
Mine had a similar problem last year, it was the coolant temp sensor :wink:
Offline rfn_hodgson
« Reply #5 on: 22 December 2013, 18:34 »
Got cha cheers lads will replace as soon as money is available :(
