Author Topic: Coolant will not stay warm :/  (Read 2363 times)
Offline rfn_hodgson
« on: 21 December 2013, 13:43 »
Hello fellas over the past few months my engine temp seems to be struggling to stay at 90
Could this be down to thermostat??
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
VW BUSH
Re: Coolant will not stay warm :/
« Reply #1 on: 21 December 2013, 13:53 »
yep
Offline Nino
« Reply #2 on: 21 December 2013, 13:59 »
Thats a faulty thermstat, common problem and what usally happens is it wont get to 90 or you will notice it getting to 90 and when stopping dropping down to 75-80.
Ensure when you replace this that you ONLY use OEM part and you may as well change your temp sensor at the same time.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline mar_k
« Reply #3 on: 21 December 2013, 15:30 »
I've used circoli thermostats with no adverse effects. been in the car a few years with no problems.
Offline dom
  • Back in a Mk4
« Reply #4 on: 22 December 2013, 10:34 »
My circoli one lasted 2 weeks, the issue is that they are hit and miss whereas main dealer parts generally aren't.
Does the temp gauge only hit 90 when you're sat in traffic?
Offline rfn_hodgson
« Reply #5 on: 22 December 2013, 18:36 »
Yes it does but when I'm say on the motorway it's drops down to about 50-70
Or even going 40 in 6th gear
Offline dom
  • Back in a Mk4
« Reply #6 on: 22 December 2013, 18:53 »
Almost certainly the stat then :afro:
Offline rfn_hodgson
« Reply #7 on: 22 December 2013, 19:52 »
Cheers mucka G
