Author Topic: Vag-com  (Read 2962 times)
Offline 1 gti
Vag-com
« on: 18 December 2013, 18:19 »
Does anyone know how to display miles to empty? Also, I'm sure I heard someone on here they could workout an estimate BHP using vag-com. Any help is much appreciated  :smiley:
Offline dom
  • Back in a Mk4
Re: Vag-com
« Reply #1 on: 18 December 2013, 19:19 »
You need immo3 clocks to enable MTE and it can be done with Vagcom.
As for working out BHP, you need to log MAF readings with vagcom
Offline 1 gti
Re: Vag-com
« Reply #2 on: 18 December 2013, 19:36 »
How do you check what clocks you got? Any guide on how to do it?
Offline dom
  • Back in a Mk4
Re: Vag-com
« Reply #3 on: 18 December 2013, 19:45 »
What year is the car? The only way to be certain is to check the part number which is on a sticker on the underside of the clocks
Have a look here:
http://uk-mkivs.net/topic/10689-mk4-golf-and-bora-speedo-instrument-cluster/#1096416
Offline Nino
Re: Vag-com
« Reply #4 on: 18 December 2013, 22:03 »
Dom, you cannot code MTE with Vagcom, only vag techco can do that or so Ive been told.
You can however check what cluster you have using vagcom.
If you have the VDO immo 3 its done easyly with vagtechco if you have the Bosch immo 3 then you can't.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline dom
  • Back in a Mk4
Re: Vag-com
« Reply #5 on: 18 December 2013, 22:05 »
I'm sure Craig@Carbon just used vagcom with mine
Offline Rhyso
Re: Vag-com
« Reply #6 on: 18 December 2013, 22:07 »
Vag tacho  :wink: or vag kommander or something like that
Offline Nino
Re: Vag-com
« Reply #7 on: 18 December 2013, 22:08 »
like I said im only going by what I have been told that vag techco is the only way to code MTE.
Offline Rhyso
Re: Vag-com
« Reply #8 on: 18 December 2013, 22:09 »
Its the only method I have used
Offline dom
  • Back in a Mk4
Re: Vag-com
« Reply #9 on: 18 December 2013, 22:11 »
I stand corrected, I thought it could be done via vagcom
