Author Topic: Bbs lm help  (Read 1752 times)
Offline wolfie1981
Bbs lm help
« on: 18 December 2013, 13:09 »
Just been offered a set of 19" bbs lm 8" fronts / 9" rears cheap!! There 5x112 is it worth buy the adapters to make then 5x100 .
And if so what size rears adapters would be best and for the front.
Only thinking of doing this cos there cheap!!
Many thanks
Offline navmk4gti
Re: Bbs lm help
« Reply #1 on: 18 December 2013, 13:22 »
If they original bbs and cheap then go for em :wink:
Offline wolfie1981
Re: Bbs lm help
« Reply #2 on: 18 December 2013, 13:25 »
Any clue to size of at adapters to use for the front and rears. I've seen 20mm rear and 15mm front
Re: Bbs lm help
« Reply #3 on: 18 December 2013, 13:41 »
Are they genuine if not then they are not worth the hassle, the fitment will be tight by the time you include adaptors
Offline mcgee9t2
Re: Bbs lm help
« Reply #4 on: 18 December 2013, 14:44 »
id try for 10 or 15mm adaptors if your going to put normal sized tyres on, if your going to strech tyres id go 15 or 20mm rears will be tight though. my wheels are around 8j iirc and theres not much room on the back (i have no strech, if i streched i could proberbly fit a 9j wheel there, but would be tight)
Offline dom
  • Back in a Mk4
Re: Bbs lm help
« Reply #5 on: 18 December 2013, 16:38 »
You can't really talk about fitment without knowing the offset :wink:
Generally the smallest adaptors you can get are 15mm, as long as the offset isn't mega low they should fit fine.
Many thanks
Are they genuine or reps? And how cheap? If they're reps and more than £200 then they're not worth the hassle, if they're genuine it's a different story.
Offline wolfie1981
Re: Bbs lm help
« Reply #6 on: 18 December 2013, 19:40 »
they are reps mate was looking £250 for them. im going to leave it.
just been to see a set of vmr's 5x100 for the same money and they come with spacers think I might take these
