Author Topic: Front strut brace  (Read 4647 times)
Offline Mcwill
Front strut brace
« on: 12 December 2013, 21:08 »
Hi guys, will a front strut brace fit ok with abf engine?
Offline Mr Blue
Re: Front strut brace
« Reply #1 on: 12 December 2013, 21:17 »
A 16v brace might clear but I would be more concerned about drilling into the top struts. Rust and permanent holes.
Offline Mcwill
« Reply #2 on: 12 December 2013, 21:48 »
Thanks for reply mr blue, dint think about the drilling into the top struts and thinking about it the passanger side one has got a blob of rust on it :huh: dam it ordered one now :angry:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 12 December 2013, 23:37 »
Don't they fit over the existing strut mountings?
Thom
Offline Gambit
« Reply #4 on: 13 December 2013, 08:50 »
Need to drill holes in turret for the base plates. Not a big deal really, just treat the bare metal. Front brace makes a fair difference on a mk2
Only brace i know that clears it would be an eibach. It might be tight with others, i know my omp one is tight and its not a tall back 2.0
Offline Mcwill
« Reply #5 on: 13 December 2013, 13:58 »
The one I have ordered is the jom one so doesn't sound like it will fit :angry:
Offline Sgt_Lemon
  • 8v owners club
« Reply #6 on: 15 December 2013, 20:15 »
Possible dumb question. How does putting a strut between the two top plates (not the suspension itself) help the handling? Is it worth getting one?
Offline Thom89
« Reply #7 on: 15 December 2013, 21:42 »
Not a dumb question at all, you either know, or you don't
Basically, it stiffens the chassis, so under hard cornering you get a more precise feel to the car... very much placebo effect on a road car though that has one fitted with no other, or little other chassis/suspension mods,
A brace can also be fitted that connects the lower track control arms transversely under the car, for the same reasons, rigidity.
A strut brace can also be fitted in the boot, linking the rear struts together...
Thom
Offline matt@onlychargeddubs
« Reply #8 on: 16 December 2013, 10:56 »
As above, stops the body flexing.
Personally, if you're bothered get a lower one for the subframe, you'll get more noticeable gains from this and you're not drilling holes in a place you will later regret! Struts braces in engine bays look terrible IMO and especially on an old classic car, they don't want more holes drilling in them :cry:
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 16 December 2013, 11:34 »
TBH for a strut brace to make significant difference the mounting plates should be welded to the strut tops, not bolted/screwed to them.  That's just ghey.
