Author Topic: tyre pressures  (Read 5689 times)
Offline pottinger
tyre pressures
« on: 12 December 2013, 09:31 »
hey guys,
Just wondered... did a search and cant seem to find anything....
anyone got an idea for the best tyre pressure for ed35 19 inch glendales...
thought 35psi front and rear would be ok but just thought checking here would be wise  :grin:
any help appreciated peeps
ta
potts
2011 5dr GTI, carbon Grey, DSG, and looovin it !
Offline dubber36
Re: tyre pressures
« Reply #1 on: 12 December 2013, 10:43 »
Whatever the sticker in the fuel filler flap says.
The recommended pressures are what are required to support the weight of the car, regardless of the size and shape of container, i.e. the tyre, the air is in.
Offline eug2huge
Re: tyre pressures
« Reply #2 on: 12 December 2013, 12:13 »
My gti with 18in monzas is 2.6 bar (38 psi) if that helps.
Yes, check inside fuel cap.
Offline Mattyj
Re: tyre pressures
« Reply #3 on: 12 December 2013, 12:42 »
Not all fuel caps have correct tyre size as fitted to car fallen fowl of this before
Offline dubber36
Re: tyre pressures
« Reply #4 on: 12 December 2013, 13:14 »
As I said Matty, it doesn't matter what size tyre you have. Pressure is pressure whatever size of container it's in.
Offline pottinger
Re: tyre pressures
« Reply #5 on: 12 December 2013, 13:23 »
ah ok, I will have a look in the fuel filler flap when I get home...
On another subject, dealer cock up may mean I have to get rid of a pair of BRAND NEW (stickers still on them)
Pirelli p-zero 225/35/r19 88y RUNFLATS as glendales are not runflat rims....
any pointers on best place/way to do this (think they rrp £220 to £260 a piece) I only want about £180 a piece collected but hate ebay... wonder if there any other forums anywhere worth offering them too ?
cheers for any advice
potts
Offline Booth11
Re: tyre pressures
« Reply #6 on: 12 December 2013, 14:26 »
Pottinger, I'm on 19" Glendales and it's 41psi (2,8 bar) for normal load and 44psi (3,0 bar) for fully loaded car (as shown on fuel filler cap).  Same for front and rear.
Course you've got the extra weight of the Ed35 wing badges to factor in  :grin:
« Last Edit: 12 December 2013, 14:39 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline mwad gti
Re: tyre pressures
« Reply #7 on: 12 December 2013, 14:28 »
I'm on 19" Glendales and it's 41psi (2,8 bar) for normal load and 44psi (3,0 bar) for fully loaded car (as shown on fuel cap)
BMW forums might be worth a try (they use runflats).
Not sure how welcome you'd be joining a forum just to sell something though  :whistle:
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
Offline pottinger
Re: tyre pressures
« Reply #8 on: 12 December 2013, 16:39 »
Spooky, my fuel filler cap says 39psi front/rear normal, extra loaded 42f/44r  :undecided:
So I've stuck 37 in front and rear to start with as don't want mega hard ride  :rolleyes: the tyres only had 26psi in them, bloody dealers !
I also found the front Falken f453 tyres say max pressure 40psi ? :rolleyes:
Vw dealer put them on new but surely they shouldn't have if the tyre doesn't meet the criteria of the car or is that just being overly critical ?
Potts
Ps good shout on BMW forum, may give it a try ;)
Offline Mattyj
Re: tyre pressures
« Reply #9 on: 12 December 2013, 17:24 »
This was point excatly mate i'm running falkens on the front at 35psi had no probs be getting another set for the back when the conti's burn out
