Author Topic: mk4 golf 1.8t problems  (Read 4270 times)
Offline johnnyvr6
  • golf v6 4motion soon to be 1.8t'd
« on: 11 December 2013, 17:24 »
hi i have just picked this up fair cheap,i think the owner was abit optimistic with the power lol,anyway i have noticed the revs go up and down on idle and it feels like its holding back then all of a sudden the power is there more when cold,my old agu feels quicker and that only had a remap,also its quite bad on juice i would say my 4mo golf was better,what do you think could cause this,the link of the car
http://www.swapz.co.uk/swapz/4057251/golf_gti_turbo_agu/
Offline navmk4gti
Re: mk4 golf 1.8t problems
« Reply #1 on: 11 December 2013, 18:00 »
Get it on vagcom..but sounds like maf is gone
Offline johnnyvr6
« Reply #2 on: 11 December 2013, 18:11 »
ok cheers I don't have vag com but I'm getting a maxiscan off ebay,I'm also thinking it could be a coolant temp sensor
Offline davidgtrr34
« Reply #3 on: 11 December 2013, 18:16 »
I had the same problem and it was the maf
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline johnnyvr6
« Reply #4 on: 11 December 2013, 18:18 »
ok cheers if I unplug the maf and it runs better does that mean it's defo gone before I spend money
Offline navmk4gti
« Reply #5 on: 11 December 2013, 18:18 »
Buy a vagcom off ebay and scan it with proper stuff.
Only 6-7 quid
Offline davidgtrr34
« Reply #6 on: 11 December 2013, 18:22 »
not sure but when I unplugged mine I had more power.
also a faulty maf will throw up a load of random fault codes.
I had 7 codes because of it
Offline johnnyvr6
« Reply #7 on: 11 December 2013, 18:32 »
ok thanks a lot I will give it a go tomorrow
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 11 December 2013, 22:24 »
If it is the coolant sensor unplugging the MAF would also cure that, you need a scan to pin point the problem
Offline johnnyvr6
« Reply #9 on: 11 December 2013, 22:27 »
ok cheers will look at changing both
