Golf mk3
hardmonkeys
rear disc
Topic: rear disc (Read 1868 times)
danmusic24
rear disc
11 December 2013, 13:50 »
Needs to replace rear disc,can't remember if you can just swap them or you need to replace wheel bearings( bearings pressed into disc?)
spikenipple
Re: rear disc
11 December 2013, 14:01 »
Bearings are pressed into the disc.
danmusic24
Re: rear disc
11 December 2013, 14:12 »
Thought so! Can you buy disc with bearings in them?
leigh_harty
Audi AGU
Re: rear disc
11 December 2013, 14:19 »
Quote from: spikenipple on 11 December 2013, 14:01
Isn't the race pressed into the disc (both sides mind) and the bearings placed onto the race then sealed?
I used a hammer and tap and took my time, never had a press
Dont lose your dinosaur!
gasketface
Re: rear disc
11 December 2013, 14:40 »
do'nt forget your ABS rings if you have ABS.You can often get them off your old discs but they are quite fragile and often break.
danmusic24
Re: rear disc
11 December 2013, 14:48 »
Done it before no need for press! Just thought maybe you could buy as a complete unit
Golf mk3
hardmonkeys
rear disc
