Author Topic: Not clued up at all on diesels!  (Read 6692 times)
Offline Rhyso
Re: Not clued up at all on diesels!
« Reply #10 on: 13 December 2013, 18:33 »
Black smoke = boost leak
My money is on a popped lower intercooler hose
As for Barry and Bellend; wind your fcuking necks in otherwise the ban button will be used
Offline Easy_E
« Reply #11 on: 13 December 2013, 19:01 »
What about the rattling noise when being revved though?? Could the seals have blown?? From reading on forums turbos can kill engines from sending debris back into the engine?
Thanks for your replies so far, much appreciated..
« Last Edit: 13 December 2013, 19:03 by Easy_E »
Offline Rhyso
« Reply #12 on: 13 December 2013, 19:43 »
With a pipe off it can make all sorts of noises. Check the hoses first to see if one has popped. You will need to replace it as the lugs will have worn
You may find it then cures your rattling noise
Offline Easy_E
« Reply #13 on: 13 December 2013, 20:05 »
Thanks alot buddy
Offline Rhyso
« Reply #14 on: 13 December 2013, 20:09 »
No probs  :smiley: keep us updated. Hopefully it was just a pipe
Check your oil level too. If the seals did blow then chances are you lost some oil too
Offline Easy_E
« Reply #15 on: 13 December 2013, 20:19 »
Will do pal, and i got towed to my garage on thursday  :undecided:
Offline Easy_E
« Reply #16 on: 18 December 2013, 18:24 »
Well my garage is charging me about 700 for a reconditioned turbo fitted so not as expensive as i thought it was going to be but still not good at this time of year lol  :angry:
Offline Rhyso
« Reply #17 on: 18 December 2013, 21:11 »
Ouch!!
That sounds expensive for a fitted recon unit  :undecided:
Offline Easy_E
« Reply #18 on: 19 December 2013, 16:51 »
Ouch!!
What would u call a fair price for this sort of job? I mean how long should it take? The turbo is exchange and im guessing you can get a reconditioned turbo for about 250ish?
Offline Rhyso
« Reply #19 on: 19 December 2013, 20:01 »
Ouch!!
3 hours tops maybe  :undecided:
Slightly different but my brand new turbo for my old 130tdi was about £450. Id price up a new turbo if I were you......
