Author Topic: london taxi  (Read 3404 times)
Offline danmusic24
london taxi
« on: 09 December 2013, 17:00 »
My old 16v is starting to sound like a London taxi!
I gather it's the hydraulic lifters?(are they hydraulic?)
Is it a easy job to do? And where's a good place to buy then from?
Re: london taxi
« Reply #1 on: 09 December 2013, 20:40 »
What oil are you running in it.
Offline boneybradley
  • Back in a Mk3...
Re: london taxi
« Reply #2 on: 09 December 2013, 21:16 »
How fast do you need the lifters? I know a man that can supply them  :whistle:
and as said what's your oil like? (might be worth swapping it first to see if that helps)
Offline sharki786
  • GOT BOOST??
Re: london taxi
« Reply #3 on: 10 December 2013, 07:25 »
If it sounds like  taxi then my bet would be on the waterpump bearings. A friend of mine had the same issue turns out the bearings in the water pump were gone. Replace with a good make. Or if you want to be sure check with a mechanic.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline danmusic24
Re: london taxi
« Reply #4 on: 10 December 2013, 07:26 »
Ain't the oil,changed that a while ago,it's a proper tapping noise?
Engine is not far from 170k but still goes very well.
How much can you sort lifters out for me then?
As cheap from euro car parts?
Offline danmusic24
Re: london taxi
« Reply #5 on: 10 December 2013, 07:28 »
will check it out! But noise defo sounds at the top.
Offline sharki786
  • GOT BOOST??
Re: london taxi
« Reply #6 on: 10 December 2013, 10:44 »
Same with his, the noise sounds like its comming from the top. I had same prob on my mk3, sounded like the bottom end was knocking, i was told water pump and was told to take the waterpump belt off and start the car and see if noise goes away. Which i did and the noise did go away. So take the water pump belt of and start car and see if noise is there. Also make sure your engine isnt hot when you do this.
*****MK4 GTI T*****
Offline danmusic24
Re: london taxi
« Reply #7 on: 10 December 2013, 13:40 »
Will give that ago cheers
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: london taxi
« Reply #8 on: 10 December 2013, 17:04 »
Same story for my ABF, b@stard water pump bearings!...this said it still doesn't mean the lifters arent past their best.
  • Back in a Mk3...
Re: london taxi
« Reply #9 on: 10 December 2013, 18:10 »
Quote
water pump's I have always sold qh products which seem ok quality (I have heard a few horrors about a certain ecparts place's own brand!)
I can do you a genuine hella part with or without the housing £43 without and £53 with (not the cheapest but possibly one of the best brands?)
 :wink:
