Author Topic: broken my recaro drivers seat :(  (Read 1153 times)
Offline rfn_hodgson
« on: 08 December 2013, 17:52 »
ok so earlier i was a little heavy handed and broke the (seat moving forward and back) cable plastic housing...... the cable is still intact but there is to much play in the cable for you to engage the locking mechanism.... :(
anyone know if this can be replaced/fixed ?
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline joshstanvw
Re: broken my recaro drivers seat :(
« Reply #1 on: 10 December 2013, 13:53 »
I did this the other day you will be needing access to a scrappy (or just buy the part new if u would prefer) take the seat out and you will see how it all comes apart it's fairly easy just be careful I broke the first one at the scrappy before slowly walking away to find another car to pull apart but yes the whole mechanism can be changed you can get one from basically any VAG motor of similar age mine is from a skoda Octavia vrs lol
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline rfn_hodgson
« Reply #2 on: 10 December 2013, 14:18 »
cheers mucka
