Author Topic: pls help ... car messing about  (Read 2551 times)
Offline ade_aidy_ady
« on: 07 December 2013, 18:26 »
so recently when my car is started just after moving off the EPC and traction control light come on the dash and car has a very lumpy idle and goes into limp mode .... sometimes when left for about 5 mins the car will start ok and no lights come on the dash .... when scanned it bring up the following codes .... i have cleaned the throttle body and intake air temp sensor and realigned the TB with vagcom after ! really p****ing me off as it seems to be tempremental !
only has started doing this since i changed the numberplate and puddle lights to LED ... but i doubt its got anything to do with this ??
any help much appreciated !! car is a 1.8T AUM with 80,000 miles ....
6 Faults Found:
17966 - Throttle Actuator (G186): Electrical Malfunction
        P1558 - 35-10 - - - Intermittent
17987 - Throttle Actuator (J338): Adaptation Not Started
        P1579 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
        P1545 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
        P0113 - 35-10 - - - Intermittent
Offline barrym381
Re: pls help ... car messing about
« Reply #1 on: 07 December 2013, 18:30 »
unplug your maf sensor see how it runs  :smiley:
« Reply #2 on: 07 December 2013, 18:37 »
i tried that and it made no difference to how it was running .... still ran terrible when unplugged  :cry:
Offline beppe2672
« Reply #3 on: 08 December 2013, 02:14 »
Just double check the electrical connection on the throttle body. Looks like something could be loose.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline davidgtrr34
« Reply #4 on: 11 December 2013, 19:16 »
does it idle normal or is high or moving
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 11 December 2013, 22:22 »
Have you cleared the codes after you fitted the throttle body back on?
Offline beppe2672
« Reply #6 on: 12 December 2013, 11:30 »
From the ross tech website:
There are certain test conditions that must be met before doing a TBA:
No DTC's in the Engine Controller
Battery voltage at least 11.5 V
Throttle must be at idling position (keep your foot off the gas pedal)
Throttle body part must not be dirty (carbonized).
Coolant temperature must be between 5 and 95C
If fault codes were cleared cycle the ignition off and back on prior to running Basic Settings.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 12 December 2013, 18:40 »
All of those faults are pointing to wiring IMO
