Author Topic: Static cornering bulb suggestions  (Read 5413 times)
Offline Ian.C
« on: 07 December 2013, 16:30 »
Hi there
Can anyone recommend some replacement bulbs for the static cornering lights in the GTI xenon units.....I would like the colour similar to the xenons if possible...
Thanks
Ian
3 Door - Pure White - PP
Offline Misterp
Re: Static cornering bulb suggestions
« Reply #1 on: 07 December 2013, 17:20 »
Try the h7 osram nightbreaker unlimited ebay have em for 17.99 a lot cheaper than the 40 quid other are charging
http://item.mobileweb.ebay.co.uk/viewitem?itemId=261307061766
I've ordered mine from here
« Last Edit: 07 December 2013, 17:36 by Misterp »
Golf GTD mk7 DSG pearl black - collected 25 September 2013.
Offline Jimble
  • Moderator
« Reply #2 on: 07 December 2013, 17:34 »
I went for Philips Xtreme xenon H7's, quite an improvement imo.
Offline Ian.C
« Reply #3 on: 07 December 2013, 17:41 »
Thanks guys....
Offline Mark V GTD
« Reply #4 on: 07 December 2013, 18:29 »
I will be changing them for Philips Bluevision when the time comes...
Offline Ian.C
« Reply #5 on: 07 December 2013, 19:18 »
Its difficult to know which ones will be a reasonable match to the xenons....guess ill have to try some out and hope they are ok...
Thanks
Offline monkeyhanger
« Reply #6 on: 07 December 2013, 19:23 »
You will never match the Xenons or LED for colour unless you want to reduce output a lot. Some of the bluer bulbs have quite a blue tint about them (more like a blue set of shades than a truly blue/white light output), really cuts back on the output though compared to the Osram nightbreaker series or Philips Extreme visons. Nightbreaker plus can be had quite cheap through one of the Amazon affiliate sellers or Eurocarparts, they are noticeably whiter than stock bulbs, but don't come that close to Xenons. For how long they're on for and output, Nightbreakers are fine.
Offline JamesR27
« Reply #7 on: 08 December 2013, 08:13 »
I bought a set of these ready for when my car arrives
http://www.amazon.co.uk/gp/product/B0047N0B0U/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
Needed a new set of bulbs for my mum's polo so got 2 sets. Can take a pic of the polo's headlights if you want so you get an idea? As though for amount of time they are on night breakers are a good price.
Other than that you could look into LED ones but not sure how good they will be or if they do error free coded ones.
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline VWcezGTI7
« Reply #8 on: 05 May 2015, 02:44 »
Just got my second dead bulb on the driver's side in less than 2 months. First time I changed it at the dealer's about a month ago and now the Phillips bulb they installed burned out. I really don't want to go back again so I got my own H7s with a whiter/blueish light and whenever I connect them, they work for about 5 seconds then I get an AFS error 30 seconds later.
Is there a way to reset the message without using VCDS? Do they need to be placed inside the cornering light casing for it to stop reading the error? Because when I installed them, I just left the bulbs hanging to make sure they work.
Any suggestions?
Offline Sootchucker
« Reply #9 on: 05 May 2015, 07:57 »
I had the same issue when the car was new in that I replaced the standard halogen bulbs (as supplied by VW), with higher quality Osram Nightbreakers, but they only lasted a few months before I got the Cornering Light error in the dash and found out one of them had blown. Replaced it, and the second set only lasted about 6 months before one of them blew as well. Now back on the standard crappy VW ones and they have lasted a year or so with no problem.
I would still like to change them but would like to know why the others keep failing when the cheap VW ones don't, and which units have been working for a long time without issues ?
