Golf mk3
hardmonkeys
clutch
Topic: clutch (Read 4324 times)
danmusic24
clutch
07 December 2013, 12:36 »
It's clutch time! Any benefits fitting vr6 one into my 16v?
bigberty101
Re: clutch
07 December 2013, 12:38 »
higher clamping force, more durable, holds slightly more power. worth it when you do the swap along with a lightened and balance flywheel, makers a world of difference
Foreveryoungaus16v
Re: clutch
07 December 2013, 12:43 »
16v clutch will be fine. Vr6 one only worth fitting if you running power like 1.8t etc. For a 16v you do not need a vr6 clutch. Not much in it either.
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
Foreveryoungaus16v
Re: clutch
07 December 2013, 12:46 »
Just get a Sachs 16v clutch. Thats what I did along with fitting lightened and balanced flywheel. No need for VR6 anything.
Wayne
Sir Postalot
Re: clutch
07 December 2013, 20:55 »
Just buy a decent quality 16v clutch kit, Sachs or Luk
spikenipple
Re: clutch
08 December 2013, 19:03 »
Are the Luk kits any good? They're a lot cheaper than Sachs!
Foreveryoungaus16v
Re: clutch
Reply #6 on:
08 December 2013, 19:11 »
Luk are good yes, just not as good as Sachs.
Foreveryoungaus16v
Re: clutch
Reply #7 on:
08 December 2013, 19:15 »
Quote from: Foreveryoungaus16v on 08 December 2013, 19:11
Luk are good yes, just not as good as Sachs which is a little better quality.
sharki786
GOT BOOST??
Re: clutch
Reply #8 on:
08 December 2013, 19:27 »
Get sachs. As said luk aint as good as sachs
*****MK3 Anniversary*****
*****MK4 GTI T*****
Screech16v
MK3 20vt AGU
Re: clutch
Reply #9 on:
08 December 2013, 19:44 »
I got LUK ,gets a lot of stick,no probs over a year old now.
Golf mk3
hardmonkeys
clutch
