Golf mk5
Golf mk5 TDI
Yet another problem
Topic: Yet another problem (Read 8641 times)
greg1953
Yet another problem
04 December 2013, 16:56 »
As per the title....when standing at tickover my 2005 GTTDi appears to be misfiring, it's perfectly smooth when being driven but pull up to traffic lights and you can feel it, just like a miss-fire on a petrol car.
Any ideas anyone ??
Greg
th3_f15t
Re: Yet another problem
04 December 2013, 17:15 »
Tried some Red-X through the fuel system and changed the fuel filter lately? Also, have you a way of getting the fault codes read, to see if it's throwing something up?
Moving over to Flickr, sorry for the broken picture links!
greg1953
04 December 2013, 18:17 »
Nothing on the VagCom, I've got the free version, not the dealer one and the fuel filter is about due to be done.
Greg
th3_f15t
04 December 2013, 19:20 »
I'd get that filter changed and some Red-X to clean out the lines/injectors and see if that solves it. Other than that I have no idea what would cause a diesel to run poorly at idle.
Does engine temperature affect it at all?
greg1953
04 December 2013, 20:03 »
No, it's the same whatever the engine temp is, I'll try a new diesel filter, thanks for the help.
Greg
th3_f15t
04 December 2013, 21:26 »
No worries. I'm nothing more than an home mechanic, so I'd be appreciative to know if a filter and injection cleaner clears up the problem.
Rhyso
Global Moderator
Sir Postalot
Reply #6 on:
04 December 2013, 21:58 »
Could try the following
Clean out the EGR Valve
Replace the injector loom
First one is easy enough to do yourself
Fire Up The Quattro
Golf mk5
Golf mk5 TDI
Yet another problem
