Author Topic: 1.6 Auto sluggish/ Fault codes help  (Read 5388 times)
Offline Wrensup
« on: 04 December 2013, 13:57 »
Anyone got any advice?
My girlfriends car seems to have an issue,
When driving and coming up to a junction, she'll be slowing down and rolls to the give way markings. Then when she wants to pull off again the car reacts slow (almost like you're in a manuel and you accidently try pulling off in 3rd) then all of a sudden the car will kick back down the gears fine and start to pull off alright.
Thats the best I can describe it really.
Any ideas?
thanks!
« Last Edit: 18 January 2014, 12:33 by Wrensup »
Offline Jasikasisback
Re: 1.6 Auto sluggish?
« Reply #1 on: 04 December 2013, 16:12 »
I had this. try topping up gearbox oil. either it is leaking or simply needs toping up.  It may need a gearbox filter and oil change and you can do this yourself if this has never been done. vw say some are lifetime but they expect you to drive a car for 100000miles and less than10 years. does your gearbox have a dipstick??make sure you use the right gearbox oil. don't overfill it.
Offline Wrensup
« Reply #2 on: 04 December 2013, 16:44 »
Arh right thanks I had a supsusion it could be that, I'm not sure about the dip still ill have to take a look.
Funnily enough this has just started to happen with the car on 102,000 on th clock.
« Reply #3 on: 04 December 2013, 18:30 »
good luck and i hope you do have a dipstick as that will make life very easy for you...just top up and see if it makes any difference...
Offline Wrensup
« Reply #4 on: 06 December 2013, 23:04 »
Anyone with any other suggestions, the girlfriend took it to a garage and they checked the car over apparently and couldn't find anything wrong?
« Reply #5 on: 06 December 2013, 23:07 »
I would get the oil drained and replaced plus the suction filter cleaned.
« Reply #6 on: 27 December 2013, 22:38 »
The VW dealer told me that the gearbox never has to be serviced as it is "lifetime"..I then asked if the oil in it was a special blend that doesn't break down after 20 years of use and then the line went silent and after I heard that it would cost £120 to have the gearbox oil and filter changed....so if the dealer didn't open the box and look inside then you had better do it yourself..:)
Offline tsr_adi
« Reply #7 on: 28 December 2013, 22:53 »
If by some bad luck your gearbox is at fault, I will soon have a perfectly working auto box available for beer tokens as I'm swapping to manual :)
« Reply #8 on: 08 January 2014, 05:54 »
Hi which box do you have available?
Offline Wrensup
« Reply #9 on: 18 January 2014, 12:31 »
Not sure, how can I find out?
I scanned the car, and found these fault codes:
00520 mass air flow sensor
00523 air intake sensor
00533 idle air control regulation
00525 oxygen sensor
I got a feeling these wont be helping?
Anyone know what course of action I should take first?
I know the throttle body needs cleaning for 00533
but for the others I'm not so sure?
Thanks
