Author Topic: Any idea what might be causing these oily deposits? (pic)  (Read 2858 times)
Offline MustardGTI
Not sure what this pipe attaches to, about a foot down (in the direction as indicated by the arrow) - but when sticking my hand down there, as you do, I noticed quite a lot of oily deposits around it.
I suppose my fear is that it's being caused by a leakage of boost pressure from somewhere in the vicinity, or maybe it's vapors from an engine breather system. Seems a bit much for that through.
Any thought gratefully received.
Offline mike.
Re: Any idea what might be causing these oily deposits? (pic)
« Reply #1 on: 02 December 2013, 20:25 »
Might be some related info in THIS thread.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline RocketRossUK
« Reply #2 on: 02 December 2013, 21:27 »
Yep, something has deffo failed. Usually PCV, DV, or the seals on the pipe. The odd time its the turbo but usually one of the first three.
All pretty cheap fixes. Have you checked your DV?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 02 December 2013, 23:44 »
The seals on the inlet pipe have failed leaking when the crankcase ventilation system dumps oil vapour into the inlet pipe to be burned by the turbo. As shown by my thread linked to by Mike.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline MustardGTI
« Reply #4 on: 03 December 2013, 18:02 »
Thanks for the link, seems like the likely explanation. I haven't checked the DV valve, but luckily it's still under warranty so I'll leave it in their hands.
Will undate when fixed.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 03 December 2013, 18:52 »
Good luck as my local dealers were changing turbos until I explained the true cause.  :wink:
I think the TSB has been updates since. :wink:
Mk6 GTI  &  Mk1 GTI
Offline pryda
« Reply #6 on: 06 December 2013, 08:11 »
had exactly the same problem a few months ago. was picked up at the service (done at Awesome GTi). oil was found on the DV, but when I inspected closer it originated from the air feed pipe...
20130819_193752 by Pryda_VDub, on Flickr
20130819_193810 by Pryda_VDub, on Flickr
the issue is with the cold air flow pipe failing under heavy boost. I presume the ECU is mapped?
replaced mine with a stock pipe a couple of months back and ithasn't been an issue since. Part number is 1K0 129 654 AP - costing £74 (which I thought was pretty pricey considering APR do an upgrade for £90!)
2009 MK6 GTi, Candy White 3dr, Stage 1 Revo, Milltek cat back, H&R SuperSport, RNS510, OSRAM kit
Unphased - NorthWest German/VAG/Retro Meet
Every 3rd Thursday Of The Month
http://www.un-phased.co.uk/
Offline MustardGTI
« Reply #7 on: 06 December 2013, 18:03 »
If my car is mapped then it came that way from the VW dealer when I bought it 3 months ago. I thought it was suspiciously quick above 4000 revs but don't have experience of driving others to really know.
Offline pryda
« Reply #8 on: 06 December 2013, 19:03 »
I'd be surprised if it wasn't, these parts don't tend to fail on a stock engine...
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #9 on: 06 December 2013, 19:38 »
Yes they do seen loads now including mine.
Mk6 GTI  &  Mk1 GTI
