Author Topic: L/H rear side light will not work  (Read 1070 times)
Offline lamplighter
« on: 01 December 2013, 14:26 »
Hello everyone  has anyone had this problem before im guessing someone has
my L/H rear side light will not work i have changed the bulb checked the wiring even fitted the light module into my sons gti and it works on his car so i thought lets try his light module in my gti and no it didn't work
I'm a little confused at what could be wrong the R/H side is fine even swapped that light module and the same results  everything works except the side light bulb .
If anyone has any ideas ????
Dave
Offline navmk4gti
Re: L/H rear side light will not work
« Reply #1 on: 01 December 2013, 14:35 »
Check the fuses  :smiley:
Offline lamplighter
« Reply #2 on: 01 December 2013, 14:42 »
Any idea what fuse number they would be ?
Offline navmk4gti
Offline lamplighter
« Reply #4 on: 01 December 2013, 15:04 »
Thanks for that NAV one place i didn't look was the fuses mini 5amp blown haven't got one that size  will nip to halfords in the morning
Thanks again
Dave
Offline navmk4gti
« Reply #5 on: 02 December 2013, 11:05 »
No probs get that fuse changed should sort it :smiley:
