Author Topic: lossing boost  (Read 1440 times)
Offline KCP
  • golf 1.8t AGU/ Audi s6 2.2t auto/ bettle 1303
lossing boost
« on: 01 December 2013, 12:28 »
hi can anyone help I keep losing turbo boost on my car first time it happened it was a hole in a pipe then it was the n75 valve that I replaced with a new one now its doing it again im thinking of replacing all the pipes with silicon ones and hoping that will sort it does anyone know if it could be anything else
why didn't I just leave it alone lol
Offline davidgtrr34
Re: lossing boost
« Reply #1 on: 11 December 2013, 19:30 »
is it hitting good boost and then dropping very fast or does it drop slow.
14 psi is all the map sensor will let you get and then it will drop boost to around 3-5 psi
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline joshstanvw
Re: lossing boost
« Reply #2 on: 11 December 2013, 21:52 »
just for your piece of mind check check and check again all your boost piped i had a hideous issue when my charge pipe disconnected itself whilst overtaking a lorry it just sounded like a massive whooshing when it wanted to boost and when you sat still and gave it a small rev it sounded like it had a badboy blow off valve lol (embarrassingly it took me 45 minutes to find a pipe that was completely disconnected)
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: lossing boost
« Reply #3 on: 11 December 2013, 22:14 »
Actuator?
Offline KCP
Re: lossing boost
« Reply #4 on: 05 January 2014, 11:44 »
hi
 some days it works fine other days it just was not there I have changed my pipes for silicon ones and I think it has done the trick
 :smiley:
Offline KCP
Re: lossing boost
« Reply #5 on: 05 January 2014, 11:46 »
how can I tell how much psi I am getting?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: lossing boost
« Reply #6 on: 05 January 2014, 12:17 »
what engine code do you have? Easiest way is a boost gauge although on the models with a MAP sensor you can read it off VAG COM
Offline KCP
Re: lossing boost
« Reply #7 on: 07 January 2014, 14:27 »
its a AGU is that what you mean ?
