Author Topic: Side light bulb change  (Read 1855 times)
Offline Mattyj
« on: 30 November 2013, 12:11 »
As above has anyone changed them i read on an online vw workshop manual you don't need to remove headlight i think this is untrue i can barely get two fingers into the light to touch the sidelight bulb with little access also not being able to see what your doing (as usual) doesn't help
Offline legg360
Re: Side light bulb change
« Reply #1 on: 30 November 2013, 12:35 »
I changed mine for a set of LED ones, had to remove the air box on one side and then used a small pair of pliers to grip and pull it out, it just pops in no turning or anything just a straight pull backwards. On the drivers side there is more room but again reach inside with some pliers (be carefully not to get any wires trapped) give it a little tug and it will pop out no need to remove the lights
Golf GTI MK6 5dr Manual - Candy White with Jacara Cloth, Vancouver 18" Alloys, RNS 510, Cruise Control, Carbon Vinyl Wrap Roof, Milltek 3" Race Cat Back.
Offline Mattyj
« Reply #2 on: 30 November 2013, 13:29 »
Cheers mate nice to get some useful info out of this forum just done them now not too bad in the end like key hole surgery lol
Offline legg360
« Reply #3 on: 30 November 2013, 13:41 »
That's the reason im on here as well, not had my golf long and learnt loads from being on here... down side tho you see things and it puts ideas in your head expensive ideas lol
Offline Mattyj
« Reply #4 on: 30 November 2013, 14:33 »
Oh yea had those already tho lol
