Author Topic: porting exhaust manifold ko3s?  (Read 2328 times)
Offline davemk4
« on: 29 November 2013, 14:52 »
In prep for stage 2 power which im trying to get most bhp as possible. I will be replacing the actuator with a forge one. Whilemanifold off thinking of porting the manifold (in fact ill prob pick up a used one to port ready then swap them over. ) is this a good job to do DIY? Any one done it with good results?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline davemk4
Re: porting exhaust manifold ko3s?
« Reply #1 on: 11 December 2013, 20:45 »
 :whistle:
Offline rockmonkey69
« Reply #2 on: 11 December 2013, 22:09 »
Not fitted mine yet, I'm going to change the turbo and manifold at the same time, got the car booked in for the remap so I'll do it shortly before the remap
Most of the material was removed from the collector
Offline markgti1.8t
« Reply #3 on: 11 December 2013, 22:43 »
what did you use to do this
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline davemk4
« Reply #4 on: 12 December 2013, 07:46 »
Ye what did u do?
Offline mar_k
« Reply #5 on: 12 December 2013, 07:49 »
Carbide bit it what I was advise to use.
« Reply #6 on: 12 December 2013, 08:36 »
Carbide bit made light work of the porting of the collector
Offline davemk4
« Reply #7 on: 12 December 2013, 11:24 »
So how kuch do you take off or is it just smooth and tidy it up best you can?
Offline beppe2672
« Reply #8 on: 12 December 2013, 11:33 »
I need to get round to doing this!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
« Reply #9 on: 12 December 2013, 14:18 »
Ideally you should open up the main restrictions but not remove any grooves/channels inside that help to channel airflow. Same applies with the collector, there's a lot that can be removed there, if in doubt check the thickness of different areas before going at it.
