Author Topic: centeral locking with indicators flashing  (Read 3488 times)
Offline xionsolaris
« on: 28 November 2013, 19:13 »
I have wired in my rclick got the easy plug in and play loom i used the red scotch locks to wire the 2 brown cables into the black/white  and the black/green wire these are supposed to be the indicators but still nothing flashes when i lock or unlock has anyone had these problems
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: centeral locking with indicators flashing
« Reply #1 on: 28 November 2013, 19:15 »
Where did you scotch lock the indicator wires exactly?
p.s. Are you sure the scotch locks are fully pushed through the plastic as the ones supplied eith the rclick kits arent particularly good. I had to squeeze mine closed with mole grips before I got them working.
« Last Edit: 28 November 2013, 19:19 by thai-wronghorse »
Offline xionsolaris
« Reply #2 on: 28 November 2013, 20:45 »
Right near the plug that plugs into the adapter cable which would normally plug into the pump
« Reply #3 on: 28 November 2013, 21:24 »
Wrong ones, run the cable along inside the boot lip and reconnect it to the relevant wires that come out of the lighting loom there. I looked at the ones on the drivers side initially but after tracing them back figured they werent the right ones.
Offline xionsolaris
« Reply #4 on: 28 November 2013, 21:50 »
So I splice into the wires coming out of the rear light
Offline itavaltalainen
« Reply #5 on: 28 November 2013, 23:58 »
yeah.... you need wires for indicator on rear light clusters (or central electric in the correct loom, or indicator stalk wiring); not wires in p/s pump loom
Offline spudboy6
  • Just like a golf ......
« Reply #6 on: 29 November 2013, 00:49 »
When I did mine , you have two wires in that plug and play loom for the indicators.  One left and one right , find the relevant wire coming out the Back of the lamps think its black can check in the morning , and scotch lock them there one wire to each rear lamp so you get both sides flashing.  I used the plug and play loom and had to change some things like lock button unlocked and unlock button locked but all very simple
Have you seen the thread on here about installing it. ?
Offline xionsolaris
« Reply #7 on: 29 November 2013, 07:00 »
Thanks for your help guys I will attempt this later
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 01 December 2013, 17:37 »
Decided to wire my indicators to my rclick system today,put one of the brown wires to black and green ,tried it and popped the 7.5 fuse,tryed the other brown on the same black and green and again popped the fuse,cant see the black and white for the otherside is it in the other loom that's fully wrapped,any ideas?
Offline spudboy6
« Reply #9 on: 01 December 2013, 18:25 »
So I've got my rclick unit in the boot , so you have two wires one for the left and one for the right , you need to run one wire to either rear lamp.( one to the left lamp one to the right lamp )
When I get back out to the car in a sec I'll get the wire colours for you and a pic (y)
