Author Topic: coilover adjuster nut thingy  (Read 1974 times)
Offline sharki786
  • GOT BOOST??
« on: 25 November 2013, 16:20 »
Iv had my coilovers for a few years now. I never greased them as my unc said dont  :rolleyes: yes i know
Well now i need to set them up as the pas side is higher then drivers but when i set them i set them all same. Anyway i need to free up the adjuster. Whats the best lube like wd40 to use to loosen them up?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Shizzle
Re: coilover adjuster nut thingy
« Reply #1 on: 25 November 2013, 16:26 »
When i did mine i had to use oxy acetylene to loosen mine as they had been stiff for a while once loos those very easy to adjust mine were bad though wd40 done nothing to helping before heat was applied.
Just make sure you clean them before trying to loosen them lots of dirt in thread wont help of and  i used a hammer and blunt screwdriver for the 1st few turns not recommended really but worse case.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 25 November 2013, 16:58 »
Soak them overnight in Plusgas.
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 25 November 2013, 17:39 »
Cheerio me ol chaps :wink:
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
« Reply #4 on: 25 November 2013, 17:55 »
Plusgas should do it, wire brush on the threads before trying to move them. Be careful when hammering the adjusters as they'll damage easily.
« Reply #5 on: 26 November 2013, 20:08 »
If you do free them off all ok, be sure to coat the threads in copper slip will stop them seizing again.
Offline mcgee9t2
« Reply #6 on: 26 November 2013, 21:44 »
get some penetrating fluid or similar. then wire brush them as said then once there free copper slip them.
Offline Bellend
« Reply #7 on: 26 November 2013, 22:21 »
Hacksaw nearly all the way though so you don't damage the thread then hammer a screwdriver down the slot to split the adjuster. Then buy new adjusters.
I personally would clean up with a weak hydrochloric acid solution then grease them right up after. But that's me.
Where all my moneys went.
