Golf mk2
Rear wiper connections
Topic: Rear wiper connections (Read 2237 times)
philstar
...life is all about creating memories...
24 November 2013, 14:31 »
I have just purchased a 1989 16v GTi and the rear wiper doesnt work. Having looked into it, I only have a single outlet on my washer bottle pump, and underneath the header tank there seems to be another multi-connector and a very thin hose that aren't connected to anything.
Photo of connector and thin pipe, header tank removed:
https://plus.google.com/u/0/photos/114746994541856658936/albums/5949830986036199297/5949830987146348466?pid=5949830987146348466&oid=114746994541856658936
So my question is, how should my rear wiper be connected? Should it run off the washer bottle using a twin outlet pump or is there a separate reservoir and pump for the rear wiper? What is the connector and thin pipe meant for?
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Gambit
Forum addict
Re: Rear wiper connections
24 November 2013, 16:04 »
Your pic link doesnt work. There is only on resivoir and a 3 port pump serving both front and rear washers
philstar
24 November 2013, 16:16 »
https://lh5.googleusercontent.com/--ghfHZkUTu0/UpILwl54R7I/AAAAAAAAERg/bAjFCNN6A5k/w401-h534-no/IMG_20131123_122238.jpg
Hopefully this link works...
weazgti
24 November 2013, 22:51 »
Fog light plug is under header tank.
philstar
25 November 2013, 09:18 »
Does anyone have a photo of the same area on their car so I can see what it should look like? No experience with golfs yet. Mine is an '89 16v
Ben@VWH
Forum Supporter
GTI forum regular
25 November 2013, 09:39 »
Sounds like you need a twin outlet washer pump and to connect the loose pipe you have to the extra port on the new pump.
http://www.vwheritage.com/vw_spares_Washer-pump-2-outlet-Glf-Mk2-12-85-7-92-req-wiring-333955651_act_shop.product_pID_16385921.htm?crumbStartPage=4&crumbStartRow=46
This does require a very minor bit of wiring as the connector is different.
mr_brown
Reply #6 on:
25 November 2013, 13:24 »
This is what you're missing, including the short length of tube attached (that fits onto the hard line to the rear in your pic)
How it should look in the bay
philstar
Reply #7 on:
25 November 2013, 21:06 »
Excellent! Thanks very much! The only remaining issue now is that multi-pin connector under the header tank...
Golf mk2
