Golf mk2
Measuring exhaust for new back box - Ashley original system
Topic: Measuring exhaust for new back box - Ashley original system (Read 6954 times)
Mart8V
I really should know better by now.....
24 November 2013, 10:07 »
Hi All,
Right- Have a back box on my new 8V which is so loud that I can't hear my kids from the back seat and it needs to go. Will be putting a standard one back on!
Question- the whole system is an aftermarket with a 4 branch which will be staying on. The EXTERNAL pipe diameter is 2.25" (57/58mm) according to the vernier on the centre pipe (flange on back box obviously wider) which would leave me needing a 16v back box to fit on it all. Am I correct in A- where to measure and B- the standard diameter of the 16v pipes?
Thanks!
ED- Have taken the punt and ordered new part. Will see!
Last Edit: 05 December 2013, 15:48 by Mart8V
Sgt_Lemon
8v owners club
Re: Measuring exhaust for new back box
24 November 2013, 13:46 »
On the silencers it might say what make of exhaust it is. That size external diameter sounds like it would have an internal of 2" which is standard for 8v. The 16v has a standard internal of 2.5" which is bigger than what you currently have on.
Mart8V
24 November 2013, 14:40 »
You sure about the 2.5 for the 16v? I thought it was 2 1/4 inches?
Oh, and outside casing is so dirty etc that I can't find any markings, sadly. Looking at the Scorpion boxes on the TSR site they list both 8v and 16v as the same bore. Confused!
Last Edit: 24 November 2013, 15:03 by Mart8V
Gambit
Forum addict
24 November 2013, 16:10 »
16v is defo 2.25inch outer diameter
Mart8V
24 November 2013, 19:38 »
Quote from: Gambit on 24 November 2013, 16:10
Thanks, puts my mind at rest!
Sgt_Lemon
8v owners club
25 November 2013, 15:25 »
sh!t sorry, my bad. Always assumed you would use an internal measurement.
http://www.edition38.com/forums/index.php?showtopic=270821
Mart8V
Reply #6 on:
05 December 2013, 15:41 »
Thought I had this sorted and am now just hacked off.....
System starts with a four-branch (great!) which is 2" outer dia at the connection to the front silencer. Then it steps up from 2" on the front end of that section to 2.25" (16v?) and that is the trend all the way back.
ED- Looks as though this is an Ashley system.
The system is way too loud for me so bought a standard 16V rear box thinking it would fit- it doesn't, as the centre box outlet is EXACTLY the same diameter as the rear box inlet where it goes over the beam.
Options:
A- Buy a complete 8V system
B- Buy a 16V front and centre box to match the rear. BUT- Is the inlet on a 16V front silencer 2" or 2.25"? Where does the diameter step up?
Have tried lots of searches on this and am now just getting tired of it!
Any help much appreciated!
Last Edit: 05 December 2013, 15:49 by Mart8V
Sgt_Lemon
8v owners club
Re: Measuring exhaust for new back box - Ashley original system
Reply #7 on:
05 December 2013, 16:51 »
How far off is it? There is none in my area but if you can find a good exhaust place (not just a fitters) they have tools that can expand the ends on a pipe so could stretch it to the correct size.
Mart8V
Reply #8 on:
05 December 2013, 17:13 »
The two pipes are the same diameter to it would need to be expanded by about 2mm all round.....
gazareth
Reply #9 on:
05 December 2013, 17:52 »
get yourself a 4"long piece of exhaust that will go over both sections and join with 2 clamps and plenty gum. like a joining sleeve.
Golf mk2
