Author Topic: Condensation on windscreen  (Read 1817 times)
Offline Mattyj
« on: 24 November 2013, 03:06 »
Had this in my fabia vrs but very bad this was due to a blown inner door card seal common fault that had soaked sound proofing and the floor carpet was wet no where near as bad in my gtd but a little there thought this was down to moisture in the car but i can't find any, any known water traps?Or problem areas?
Offline Snoopy
  • Moderator
  • Geoff.
Re: Condensation on windscreen
« Reply #1 on: 24 November 2013, 08:52 »
Are you sure its condensation on the windscreen? The reason im asking is when they are fitted at the factory there is a layer on the screen to help the robots suckers to grip the screen. Its a grey greasy substance. Mine has it on the screen and I regular have to clean it but it comes back after a few weeks.Makes it look like your looking out into slight fog. Havent found anything to shift it fully yet.
I know the issue you mentioned about the vRS infact thats my repair  job today as my SEAT leon passenger door inner seal has just done what yours vRS did.
« Last Edit: 24 November 2013, 08:55 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Snooze
« Reply #2 on: 24 November 2013, 11:09 »
Mine fogs up easily at the moment. Even with the AC off. It's much worse in my mk6 than it was in my mk5.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Mattyj
« Reply #3 on: 24 November 2013, 14:04 »
Not my sisters old mk5! That had a grommet missing from factory under the dash and water was pooring in! Lol not positive it conden no it fogs up tho and gets on my bloody nerves! What you using to seal lon door? Plumbers golds awesome goes off under water! But not sure how good it will go off in this cold weather
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 24 November 2013, 14:14 »
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=331060422670 im using that on the leon doors. Done two doors this morning but its now started to rain so having a break im doing all the doors as known my luck if I only do the one thats leaking the others will start in the middle of winter!
« Last Edit: 24 November 2013, 14:17 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline barrym381
« Reply #5 on: 24 November 2013, 14:17 »
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=331060422670 im using that on the leon doors. Done two this morning but its now started to rain so having a break.
works a treat done my leon when i had it with this  :smiley:
Offline Mattyj
« Reply #6 on: 24 November 2013, 17:38 »
Fair enough i swear by the plumbers gold can get a bit messy tho :/
