Author Topic: How to swap an ecu  (Read 3101 times)
Offline spudboy6
  • Just like a golf ......
How to swap an ecu
« on: 23 November 2013, 23:20 »
Hi guys , I had ago at chipping my ecu , I had a pc repairers fit my EPROM socket and I fitted the chip and now my car won't run
No fuel and no spark.
Issue lies with my EPROM I think as 3 pins won't take solder
So I've got fault code 00546 data wiring fault
So I think I would be better with a new ecu
As I've lost all faith in these home DIY chipping
I have a second hand ecu with matching pt number as mine
I have full vag com
Anyone know how to swap ecu's on immobiliser 1
I've read this
This procedure details how to swap engine control modules on VW/Audi/Seat/Skoda vehicles with Immobilizer I.
Contents [hide]
1 Determining IMMO-ID
2 ECU Swapping
Determining IMMO-ID
[Select]
[25 - Immobilizer]
or in vehicles with Immobilizer included in Instrument Cluster
[17 - Instruments]
Look at the first "Extra" field. You should see something like: Immo-ID VWZ7Z0W0648696.
[Close Controller, Go Back - 06]
ECU Swapping
Prerequisites:
Battery voltage at least 12.0 V.
[Select]
[25 - Immobilizer]
[17 - Instruments]
[Login - 11]
4-digit PIN
Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
[Do it!]
[Adaptation - 10]
Channel 000
[Read]
[Save]
[Done, Go Back]
Switch OFF the ignition and after 5 seconds switch it ON again.
Make sure NOT to start the car within the next 2 minutes. After that, try starting the engine.
Seems easy and where do I find the spoken off PIN number ?
« Last Edit: 24 November 2013, 00:11 by spudboy6 »
Offline Wazzzer
  • Golf GTI 1.8T AGU
Re: How to swap an ecu
« Reply #1 on: 28 November 2013, 18:52 »
that's instructions for immo3 ECU swapping, what car are you trying to swap it with?
Offline spudboy6
« Reply #2 on: 29 November 2013, 00:33 »
Haven't updated this yet. ,
I swapped my faulty ecu with a known working second hand one from the same engine code ect with same ecu number used the steps above and it works fine
Thanks
