Author Topic: Trying to find oil leak  (Read 1240 times)
Offline lamplighter
« on: 23 November 2013, 21:25 »
Hello  if anyone has any ideas on this please share
My Aum has an oil leak from behind the exhaust manifold well i say from behind the exhaust manifold im seeing a lot of fresh oil on some of the pipes at the back of the engine and the engine also smells
I have just changed the charge pipe top middle and bottom and new t clamps as that was leaking but that's in a different place anyway had a look round the back but just cant identify where its coming from  oil levels have gone down a bit but im due for a service now anyway so its about right .
could it be the banjo seals that have finally given up ???
Dave
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Re: Trying to find oil leak
« Reply #1 on: 25 November 2013, 10:01 »
Have you considerd the rocker cover gasket? Mine was leaking from there for a while, garage changed it but the gasket split within a week. Got another one sorted free of charge. If your turbo pipes, and the whole back of the engine is oily, it's likely to be that.
I thought Volkswagens were supposed to be reliable?
Offline mcgee9t2
« Reply #2 on: 25 November 2013, 12:48 »
was thinking something like one of the gaskets going at the back of the engine
Offline lamplighter
« Reply #3 on: 28 November 2013, 16:57 »
Hi all the rocker gasket had been changed a few months ago and all dry ,  but i have now since changed the charge pipe to an agu version due to the stupid clip system that was given to this car and now the car is running great .
when i put my hand round the back of the engine before the turbo the pipes there are wet with oil its fresh so its coming from something round there will have a look on ekta to see if i can spot some pipes in the diagram in the same location at to where im feeling oil .
Offline mar_k
« Reply #4 on: 28 November 2013, 20:06 »
Is there oil on top of the gearbox?
Could be the VVT gasket.
