Golf mk2
rear calipers
Topic: rear calipers (Read 1697 times)
gazareth
rear calipers
23 November 2013, 15:51 »
hey guys do any of you know if the later mk2 golf rear brake calipers is a direct fit to the early mk2. I know the handbrake mechanism is located different. but will it fit with out changing cables or hoses?
Sgt_Lemon
8v owners club
Re: rear calipers
23 November 2013, 17:14 »
If they do fit then so should mk3 and some mk4 rear brakes. Unless you already have the later mk2 ones it is probs worthwhile upgrading to the newer ones as the handbrake mechanism isn't exposed for winter and shouldn't freeze the brake on.
Gambit
Forum addict
Re: rear calipers
24 November 2013, 09:50 »
Only handbrake cables are different between early & late mk2 rear calipers, and just for reference using mk4 rear calipers you need different rear hoses as they have different banjo's
Golf mk2
rear calipers
