Author Topic: Clutch Query  (Read 1651 times)
Offline Whysub
Clutch Query
« on: 23 August 2005, 11:09 »
Thought the clutch on my Golf 1.6 was on the way out, as it was slipping.
Took it out this morning, and it only slips when pulling away-which is a little unnerving when I need maximum accelleration away at a busy roundabout.
However, it will not slip under any other circumstances- not matter how hard you boot it, in any gear, it refuses to slip.
I now think that it is the cable, but the clutch pedal action is very light compared to other Golfs I have driven. The adjustment looks fine, although it does realease t the top of it's travel.
Any ideas? New cable, oil the cable, adjust it (though I do not see how), or new clutch.
Thanks
Judderi
Re: Clutch Query
« Reply #1 on: 23 August 2005, 11:12 »
If you have an adjustable cable then adjust it. If you dont then buy an adjustable cable as the auto adjusting ones are poo.
Offline Whysub
Re: Clutch Query
« Reply #2 on: 23 August 2005, 20:40 »
Thanks-I'll get an adjustable one and fit it tomorrow.
Offline [han]
  • Graphic Designer for Haribo
Re: Clutch Query
« Reply #3 on: 24 August 2005, 08:31 »
i STILL have my similar problem... hope you get urs sorted before i get mine done.. will prob do it after e38!?
Offline Whysub
Re: Clutch Query
« Reply #4 on: 24 August 2005, 13:01 »
Sorted-local VW specialist took it for a drive and comnfirmed it is the cable (commented on how light the pedal action is-how heavty is a heavy one then?) rather than adjustment. Pissing down, and as it is so little labour time, they wll do it tomorrow
I'll let you know the outcome/cost.
Offline Whysub
Re: Clutch Query
« Reply #5 on: 26 August 2005, 10:24 »
Bugger-despite initial analysis, it appears that not only is the cable buggered, but the clutch is completely worn out, and needs changing. I will seek a second opinion, but then I think I am clutching (no pun intended) at straws and putting off the inevitable :undecided:.
Now need to find somewhere that can do it cheap in Essex. No time or aptitude to do it myself :embarassed:
