Author Topic: Reverse light too dim!  (Read 7316 times)
Offline Mattyj
« on: 22 November 2013, 23:19 »
Any tips? Retro fits? Etc way to dim can't see where i'm reversing
Offline tenrohle
Re: Reverse light too dim!
« Reply #1 on: 24 November 2013, 18:24 »
Crazy as this sounds I never thought of a reverse light as something designed to light up your path when you're going backwards, more of a light to let people know you're going backwards.
Offline Mattyj
« Reply #2 on: 24 November 2013, 18:34 »
Yea fair one but my fabia vrs actually lit the rear up a bit its nice to see where your reversing in the pitch black
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 24 November 2013, 19:38 »
Do you have the normal lights on the 2009 and early 2010 cars or the led version rears from the later car.
The normal lights are not too bad but the led ones are rubbish.
Im going to fit the reversing camera because of the poor led reversing lights as my house is not near any streetlights and is pitch black it makes reversing into the drive and garage difficult.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline Eeef
  • Lord of War
« Reply #4 on: 24 November 2013, 21:39 »
Given that it's not illuminated for any length of time, I'd have thought that you could safely up the wattage without too great a risk of torching the loom.
Offline Jimble
« Reply #5 on: 24 November 2013, 21:45 »
Always annoyed me on the mk6 that it had one reverse light and one fog light! My OCD tells me it should have two of each!! >:(
Offline dubber36
« Reply #6 on: 25 November 2013, 08:04 »
Hazard lights help  :wink:
Offline Poached
« Reply #7 on: 25 November 2013, 09:01 »
Reverse camera is actually a useful item to have.
Offline Mattyj
« Reply #8 on: 29 November 2013, 22:16 »
Defo prefer two lights and a bit bigger not saying fit a vulgar massive thing but seeing whats behind is important as i often drive through dark unlit single track roads and standard none led
Offline Keithuk
« Reply #9 on: 30 November 2013, 02:04 »
Two reversing lights on a mk6 Golf would be nice but VW have cut the price to a minimum when there is plenty of room for two, alot of othe VW's only have one.
A dim light means a duff bulb or low voltage which it bad connections or earth.
You could get your motor scanned for any error codes logged in the ecu and post them.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
