Author Topic: 8v gti and vr6 engine looms  (Read 2361 times)
Offline sharki786
  • GOT BOOST??
« on: 22 November 2013, 19:50 »
Could anyone tell me if there is any difference in the loom from the actual engine to the fuse box? Or from the loom connector in the bay to the engine?
Im thinking about ramming a vr engine in my anni. So need advice :wink:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline xionsolaris
Re: 8v gti and vr6 engine looms
« Reply #1 on: 22 November 2013, 20:53 »
The wiring loom is completly different get a vr6 engine with the loom and it will plug into your exsiting fuse box
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 23 November 2013, 11:02 »
I thought from the fuse box the wiring would be same. Only place it would be different would be the connector on side of engine
*****MK4 GTI T*****
« Reply #3 on: 23 November 2013, 13:39 »
Nope, it is very different with lots of extra sensors etc so you will need the engine loom as well.
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 23 November 2013, 16:10 »
I put it down wrong i thinks. Theres 2 parts to the loom. The part thats on fuse box and then the loom from engine. On my agg you have the black round connector on the side of engine (gb side) thiz then goes to the fuse box. If not then il just get the lot.
*****MK4 GTI T*****
« Reply #5 on: 23 November 2013, 17:25 »
It is different, you will need the loom from the fusebox to the engine as well as the engine harness.
